The OnInitIncludeFile event is called once for each include file script to initialize it. Implementing this event is optional, but recommended as it allows you to provide a name, description and other information such as minimum version requirements.
| Method Name: | OnInitIncludeFile |
Argument Type: |
Return Type: |
none |
Description: |
When Opus starts up, or when an include file script is added or edited, its OnInitIncludeFile method is called. This gives the include file a chance to tell Opus something about itself, by setting the various properties of the IncludeFileInitData object. |
