reference:scripting_reference:scripting_events:ongetcustomfields
The OnGetCustomFields event can be implemented by a rename script to add custom fields to the Rename dialog. This lets you provide one or more controls that users can use to pass parameters to your script.
Method Name: OnGetCustomFields
Argument Type:
GetCustomFieldData
Return Type:
none
Description:
The Rename dialog will call this method when your script is loaded from a preset (or when you click the Refresh button in the integrated script editor).
The GetCustomFieldData.fields property lets you add one or more custom fields to the Rename dialog. For each field you can:
  • Provide a label
  • Specify a cue banner for edit fields
  • Add up/down spinners to numeric edit controls
  • Specify a length limit for edit fields
See Custom Fields in the Rename Dialog for more information.
