reference:scripting_reference:scripting_events:onaddcolumns
The OnAddColumns event is called to allow your script add-in to add columns. Call the AddColData.AddColumn method once for each column you wish to add.
Method Name: OnAddColumns
Argument Type:
AddColData
Return Type:
none
Description:
When Opus starts up, or when a script add-in is added, edited or enabled, its OnAddColumns method is called. This allows a script to add columns to Opus. A script can reinitialize its list of columns at any time by calling the Script.InitColumns method.
