Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_events:onstartup
The OnStartup event can be implemented by a script add-in to receive notification when Opus starts up.
Method Name: OnStartup
Argument Type:
StartupData
Return Type:
none
Description:
This event is only triggered when Opus starts up, therefore only script add-ins that are already installed will receive it. If a script is installed when Opus is already running it won't receive OnStartup until the next time Opus is started.
