The OnSourceDestChange event can be implemented by a script add-in to receive notification whenever a tab's source/destination state changes.
| Method Name: | OnSourceDestChange |
Argument Type: |
Return Type: |
none |
Description: |
The SourceDestData.tab property identifies the tab, and the source and dest properties identify the new state (if both are False it means the tab is "off" - this can only happen in a single file-display Lister). |
