The OnFilesystemChange event can be implemented by a script add-in to receive notification when monitored files or folders change. Monitoring is established by calling the FSUtil.WatchChanges method.
| Method Name: | OnFilesystemChange |
Argument Type: |
Return Type: |
none |
Description: |
The id property indicates which watcher detected a change. Note that you aren't told what changed, only that something meeting the specified conditions did change. |
