Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:scripting_reference:scripting_events:onfaytclose
The OnFAYTClose event can be implemented by a script add-in to receive notification when the FAYT closes (assuming it has been used with a script FAYT command).
Method Name: OnFAYTClose
Argument Type:
FAYTCloseData
Return Type:
none
Description:
The FAYTCloseData object has a tab property which identifies the tab the FAYT closed in.
