The OnDeleteScript event can be implemented by a script add-in to receive notification when (if) it's deleted by the user via the Scripts management user interface. You might want to use this to cleanup any data files your script has created.
Method Name: | OnDeleteScript |
Argument Type: |
Return Type: |
<none> |
Description: |
The DeleteScriptData.file property contains the full pathname of the script that's being deleted. |
