The OnButtonContext event can be implemented by a script add-in that adds one or more new this by adding new internal commands to Opus. Individual command arguments can be flagged as needing context-sensitive state.
For example, a function called Foo might have an argument BAR that should appear highlighted in certain situations. When the user adds the command Foo BAR to a toolbar, your script's OnButtonContext event is called to update the button's state.
The arguments that require context-sensitive state are specified when adding the custom command via the context_args property of the ScriptCommand object.
| Method Name: | OnButtonContext |
Argument Type: |
Return Type: |
none |
Description: |
