The OnAddConfigPages event is called to allow your script add-in to add one or more pages to the script configuration dialog. Any "regular" script configuration values defined by your script in OnInit are still shown to the user on the first tab of the dialog, and your custom dialogs are shown on the subsequent pages.
| Method Name: | OnAddConfigPages |
Argument Type: |
Return Type: |
none |
Description: |
The script must create a detached dialog containing a tab control with at least one tab. It must run a normal script message loop and handle all message processing as normal. The only difference is that instead of calling Dialog.Show() the script must call Dialog.AddConfigPages(), and pass through the AddConfigPagesData object that's supplied to the method. |
