reference:scripting_reference:scripting_events:onaboutscript
The OnAboutScript event can be implemented by a script add-in to display an "about" dialog to the user. It is triggered when the user clicks the About button for a script on the Script Management dialog.
Method Name: OnAboutScript
Argument Type:
AboutData
Return Type:
none
Description:
The usual implementation for this event would use the AboutData.window parameter to display a dialog using the Dialog object.
