scripting:script_editor:editors:dialog_editor:dialog_control_properties:palette_properties
The specific properties applicable to the Palette control are:
  • Palette Type: Four types are supported - normal, alpha (supports alpha values), transparent (supports a "transparent" option) and default (supports a "default" option).
  • No Arrow: Prevents the control showing a dropdown arrow glyph.
  • Can Disable: The control will display a checkbox which lets the color be turned off.
  • Decimal: Color values are reported in as decimal ("RRR,GGG,BBB") rather than hex ("#RRGGBB").
