reference:command_reference:internal_commands:go
The Go internal command can be used to:
  • Navigate to a different folder in the Lister
  • Move back and forward in the history list, and display the contents of the history list
  • Connect and disconnect network shares
  • Display a list of drives on your toolbar
  • Display the contents of a folder in a drop-down menu
  • Display a list of sites in the FTP address book
  • Open new Listers
  • Open and manipulate folder tabs and tab groups.
Command Arguments:
Possible values Description
BACK /S
(no value) Navigate to the previous folder in the history list. The history list preserves the file selection and scroll offset state of the folder. The BACK argument can be combined with the UP argument; in that case, if the previous folder in the history list is the current folder's parent, Opus will go back (preserving selections, etc) rather than UP.
You can combine this with arguments that change the target of the navigation, like NEW, NEWTAB, OPENINDUAL etc.
Example: Go BACK
BACKLIST /O
(no value) Display a list of all previous folders in the history list (acts as a dynamic button). This is used on the drop-down menu attached to the Back button on the default toolbar.
Example: Go BACKLIST
namesonly Display only folder names, not full paths. Tooltips will show full paths when hovering over items.
Example: Go BACKLIST=namesonly
noicons Does not display icons on the generated history list.
Example: Go BACKLIST=noicons
keys Assigns the accelerator keys 0 through 9 to the first ten items displayed on the generated history list.
Example: Go BACKLIST=noicons,keys
sort Sorts the history list alphabetically instead of in chronological order.
Example: Go BACKLIST=sort
maxwidth=<width> Specifies a maximum width (in characters) for each item in the list. Larger names will be truncated to stop the list being too wide. If not specified, a maximum width of 50 is used by default - you can disable this (and have no maximum width at all) by specifying maxwidth=0.
Note that because this parameter requires an equals sign, you must enclose the whole value of the BACKLIST argument in quotes.
Example: Go BACKLIST="sort,maxwidth=25"
COMPATIBILITYFILES /S
(no value) Switch between a folder and its compatibility store. Not all folders have compatibility stores - this command will do nothing in that case. For example, from C:\Program Files you would be taken to C:\Users\…\VirtualStore\Program Files, and vice versa.
The compatibility store concept was introduced in Windows Vista with the addition of UAC, to support older software that tried to save files in the program folder. These days the concept is hardly ever encountered.
Example: Go COMPATIBILITYFILES
CONNECT /O
(no value) Display the system dialog that allows you to map a network share to a drive letter.
Example: Go CONNECT
<network path> Map the specified network path to a drive letter.
Example: Go CONNECT \\server\share
COPYARGS /K/R
(no value) A command like Go FOLDERCONTENT=copy which generates a list of buttons, each of which copies or moves files to or from a different place. Each generated button runs the Opus Copy command, which takes different arguments to the Go command.
The COPYARGS argument allows you to specify one or more additional Copy-command arguments which are added to each of the generated buttons.
Since this is a "raw" argument, it should be the last thing on the line. All text after the word "COPYARGS" will be taken as-is, including any quote characters, and appended to the copy command of each generated button.
Example: Go C:\ FOLDERCONTENT=copy COPYARGS COPYFILETIMES=no
CURDIR /O
(no value) Activates "current directory" mode for the Go command. When used with a drive letter for the PATH argument, this mode makes Opus navigate to the most recently accessed folder on the specified drive. Opus will remember the "current directory" for each drive in your system, even from one session to the next.
When used in conjunction with the DRIVEBUTTONS argument, the generated drive letter buttons will have the same behaviour, and will highlight to indicate the "current drive". In this way you can click around from one drive to another remembering the previously used folder on each drive.
Example: Go D: CURDIR
Example: Go DRIVEBUTTONS=fixed CURDIR
rootmode Modifies "current directory" mode so that clicking the button for the drive you are already on takes you to the root of the drive (ordinarily it would do nothing).
Example: Go DRIVEBUTTONS CURDIR=rootmode
CURRENT /S
(no value) Indicates the current source folder. This argument is used to open the current folder in another tab, Lister or file display.
Example: Go CURRENT OPENINDUAL
DESTPATH /S
(no value) Indicates the current destination folder. This argument is used to open the destination folder in the source file display (or another Lister, or tab).
Example: Go DESTPATH
DISCONNECT /S
(no value) Display the system dialog that allows you to disconnect (unmap) a network share.
Example: Go DISCONNECT
DRIVEBUTTONS /O
(no value) Display a list of all the drives currently on your system (acts as a dynamic button). Clicking a button navigates the source folder to that drive's root. The drive buttons can also be right-clicked to display the context menu for each drive.
The various values for this argument can be used to restrict the drives that are shown.
fixed Only display the fixed drives (hard drives).
network Only display network (mapped) drives.
Example: Go DRIVEBUTTONS=network
cdrom Only display CD-ROM (and DVD) drives.
Example: Go DRIVEBUTTONS=cdrom
removable Only display removable drives (floppies, and some USB drives).
Example: Go DRIVEBUTTONS=removable,cdrom
ramdisk Only display RAM drives.
Example: Go DRIVEBUTTONS=ramdisk
mtp Only display MTP (portable) devices.
Example: Go DRIVEBUTTONS=mtp
iconlettersoff Disable the display of small drive letters as part of each drive's icon.
Example: Go DRIVEBUTTONS=fixed,iconlettersoff
iconletterson Enable the display of small drive letters as part of each drive's icon.
Example: Go DRIVEBUTTONS=iconletterson
labels Displays the label of each drive. By default only each drive's letter is shown.
Example: Go DRIVEBUTTONS=fixed,labels
noletters Prevents the display of each drive's letter, if labels are being shown using the labels keyword. Note that if you want to completely disable any text being displayed in the button you need to turn off the button's Show Label checkbox in the button editor.
Example: Go DRIVEBUTTONS=labels,noletters
multifunc The generated drive buttons will be multiple function buttons (three-button buttons) - clicking them with the left mouse button will act as if OPENINLEFT were set, the right button will act as if OPENINRIGHT were set, and the middle mouse button will act as if NEW were set.
Example: Go DRIVEBUTTONS=fixed,network,multifunc
multifunctabs Similar to multifunc, except the left and right mouse button functions will open a new tab on the appropriate side of the Lister. You can control how new tabs are opened with the NEWTAB argument.
Example: Go DRIVEBUTTONS=multifunctabs,labels,fixed
lettersbeforelabels When showing both drive letters and labels, the letters will be displayed first. Without this letters are shown following the labels.
Example: Go DRIVEBUTTONS=fixed,labels,lettersbeforelabels
offline When showing network drives, only offline drives will be shown (by default both connected and offline drives are shown).
Example: Go DRIVEBUTTONS=network,offline
online When showing network drives, only online (connected) drives will be shown.
Example: Go DRIVEBUTTONS=network,online
hideempty Hides the display of empty drives. Removable disks (floppies, card readers, DVDs) that have no media inserted in them will not be displayed.
Example: Go DRIVEBUTTONS=cdrom,removable,hideempty
+<letters> Only display the specified drive letters. Any drives not specified will be hidden.
Example: Go DRIVEBUTTONS=removable,+fhjm
-<letters> Do not display the specified drive letters.
Example: Go DRIVEBUTTONS=-d
DUALPATH /K
<path to read> Specify a path to read into the destination file display of a dual-display Lister (the standard PATH argument reads into the source file display).
Example: Go C:\ DUALPATH D:\
You can also combine this with OPENINLEFT, OPENINRIGHT and OPENINDUAL to specify explicitly which file displays the folders should be opened in (irrespective of which is the source and which is the destination).
Example: Go C:\ OPENINLEFT DUALPATH D:\
EJECT /S
(no value) Trigger an eject of the media in the drive specified by the PATH argument. This command has no effect if the drive does not have an eject mechanism.
Example: Go D: EJECT
EXISTINGLISTER /O
(no value) If the specified folder is already open in an existing lister (including inactive folder tabs in other windows) then the command will activate that lister and the appropriate tab within it and do nothing else. If another window is found then the rest of the command's arguments are ignored. If the specified path is not already open in another window then the command continues as if the EXISTINGLISTER argument had not been given.
Example: Go "C:\Program Files" NEW EXISTINGLISTER
seltabsonly Only selected folder tabs will be considered. If the specified folder is open in an existing lister, but in a folder tab which is not currently selected, then that tab will be ignored.
Example: Go "C:\Program Files" NEW EXISTINGLISTER=seltabsonly
EXPANDBRANCH /O
(no value) When Folder Expansion is turned on in Preferences, this command lets you programmatically expand folders in the current file display.
When used with no value, all currently selected folders will be expanded. You can combine this with the PATH argument to specify the item to expand by path - or in conjunction with the wild or regexp keywords, by pattern matching.
Example: Go EXPANDBRANCH
case Use with regexp or wild to make the wildcard operation case sensitive.
Example: Go EXPANDBRANCH=toggle,regexp,case PATH [a-z]+
clearselect Use with collapse to automatically clear the selection of any files or folders inside the folders being collapsed.
Example: Go EXPANDBRANCH=collapse,clearselect
collapse Collapses currently selected folders if they're currently expanded. Additionally, if a single file or unexpanded folder is selected and it's inside an expanded parent folder, the parent folder will be collapsed.
deepest Repeatedly collapses the deepest level of expanded folders.
Example: Go EXPANDBRANCH=deepest
levels: Lets you expand multiple levels at once.
Example: Go EXPANDBRANCH=levels:3
noparent When used with Go EXPANDBRANCH=collapse this prevents it collapsing the parent folder of a selected file or unexpanded folder.
Example: Go EXPANDBRANCH=collapse,noparent
regexp The PATH argument will be interpreted as a regular expression.
Example: Go EXPANDBRANCH=toggle,regexp PATH [a-z]+
script When run from a script, uses the folders added to the Command object to expand/collapse rather than selected folders.
Example: Go EXPANDBRANCH=script,toggle
subsequent Repeatedly expands a deeper level of folders every time. That is, the time this command expands the folder as normal, the second time it expands all its sub-folders, the third time it expands all their sub-folders and so on.
Example: Go EXPANDBRANCH=subsequent
toggle Toggles the expansion state of currently selected folders.
toggleall Toggles the expansion state of selected folders as a group. If any are not expanded, all will be expanded. If all are expanded, all will be collapsed.
Example: Go EXPANDBRANCH=toggleall
top Restricts the command to expanding/collapsing items at the top level, ignoring nested items. (Has no effect if the PATH argument is used to specify the item).
Example: Go EXPANDBRANCH=toggleall,top
wild The PATH argument will be interpreted as a wildcard. Note the wildcard is tested against names only, not complete paths. Any folders matching the wildcard will be expanded or collapsed, whether they are currently selected or not.
Example: Go EXPANDBRANCH=toggleall,top,wild PATH *_backup
FDBBUTTONS /O
(no value) This command acts as a dynamic button. It lets you add buttons to a toolbar that mimic the standard File Display Border buttons. The command is designed to be used on the File Display toolbar as an alternative to the standard buttons.
By default the command will add Back, Forward, Up, Copy, Swap and Toggle Layout buttons. You can use the various keywords to control exactly which buttons are added.
Example: Go FDBBUTTONS
<button keywords> Use combinations of the keywords back, forward, up, copy, swap and layout to control exactly which buttons are added.
Example: Go FDBBUTTONS back,forward - show Back and Forward buttons
Example: Go FDBBUTTONS -layout - show all but the Toggle Layout button
noicons Do not display icons for the generated buttons.
Example: Go FDBBUTTONS -layout,noicons
nolabels Do not display labels for the generated buttons.
Example: Go FDBBUTTONS swap,layout,nolabels
dropdowns Make the generated buttons drop-down buttons where applicable.
Example: Go FDBBUTTONS back,forward,up,dropdowns
FINDTITLE /K
<title string> Finds all currently open Listers with titles that match the specified string, and brings them to the front. The string to search for can be a specific title or a wildcard pattern.
Example: Go FINDTITLE *Projects*
FOLDERCONTENT /O
(no value) Display the contents of the path specified by the PATH argument in drop-down menus (acts as a dynamic button). Sub-folders in the generated list can be selected to navigate to that location, and files in the generated list can be selected to open that file. You can also right-click on items to display their context menus, and drag-and-drop files to folders (to copy or move them) or over other files (to open them). If you hover the mouse over a sub-folder it will expand to display another menu showing the contents of the sub-folder.
When used with FOLDERCONTENT only, the PATH argument supports multiple paths separated with a vertical bar (|). For example, this would let you reproduce (to some extent anyway) the Windows start menu in a drop-down menu in a Lister, by showing both the current user's start folder and the common (all users) start folder.
Note: When using an embedded function with Go FOLDERCONTENT the chosen target path is available as a variable called targetpath. It can be accessed in the embedded function as {$targetpath}.
Example: Go /start|/commonstartmenu FOLDERCONTENT
button Sub-folders in the generated FOLDERCONTENT list will appear as menu-buttons. Clicking the button part will read the sub-folder, expanding the drop-down will display its contents.
Example: Go C: FOLDERCONTENT=button
hoveropen When used with the button keyword, menu buttons will open automatically when you hover over them with the mouse.
Example: Go C: FOLDERCONTENT=button,hoveropen
nomenusel Hovering over a sub-folder will expand it, while single-clicking will navigate to it. Also forces empty folders to be hidden, even if showempty is also specified. Arguments like NEWTAB will be propagated to the commands run when folders are single-clicked.
Example: Go C: FOLDERCONTENT=nomenusel
dblclickmenu For folders with sub-items, both hovering and single-clicking will expand their sub-menus, while double-clicking will navigate to them. For folders without sub-items, a single-click will be enough to navigate to them.
Example: Go C: FOLDERCONTENT=dblclickmenu
norecurse Prevents sub-folders in the generated list from being expanded; the list will be limited to a single folder level (although sub-folders will still be displayed, you will not be able to expand them).
Example: Go C: FOLDERCONTENT=norecurse
noparselinks Prevents shortcuts from being resolved. Without this, a shortcut to a folder will be expandable just like a normal sub-folder.
Example: Go /profile FOLDERCONTENT=noparselinks
resolvedirlinks .lnk files are resolved to see if they point to folders and if so treated the same as folders (even when files would ordinarily be hidden).
Note that while similar, this option behaves slightly differently to the noparselinks keyword, particularly in relation to filters. The resolvedirlinks keyword specifically relates to links to folders, and the resolving is done earlier so they're actually treated as folders all along, meaning any filters the command uses will be compared against the link target rather than the link itself. The noparselinks option relates to links to both files and folders and is done later, and any filters will be compared against the link rather than its target.
Example: Go D:\Archive FOLDERCONTENT=move,resolvedirlinks
nocontext Prevents right-clicking items in the list to show their context menus.
Example: Go /profile FOLDERCONTENT=nocontext
nodirs Excludes sub-folders from the generated list - only files will be shown.
Example: Go /temp FOLDERCONTENT=nodirs
nofiles Excludes files from the generated list - only folders will be shown.
Example: Go C: FOLDERCONTENT=nofiles
showhidden Includes hidden files and folders in the list - without this, items with the H attribute set will be excluded.
Example: Go C: FOLDERCONTENT=nofiles,showhidden
showempty Empty sub-folders will be included in the generated list. Without this, empty sub-folders are excluded.
Example: Go CURRENT FOLDERCONTENT=showempty
includestart The generated content list begins at the specified folder rather than starting with its contents.
Example: Go C: FOLDERCONTENT=includestart
filefilter=<pattern> Specifies a wildcard pattern that the names of files must match to be included in the generated list (without this, all files are included).
Because this keyword requires an embedded equals sign, you must enclose the entire argument value in quotes to avoid confusing the command parser.
Example: Go C: FOLDERCONTENT="filefilter=*.exe"
If you need a comma (,) character within the pattern, put embedded quotes around the pattern as well. The examples below both specify *,* as the pattern:
Example: Go C: FOLDERCONTENT="filefilter=""*,*"""
Example: Go C: FOLDERCONTENT="filefilter=""*,*"",nodirs"
dirfilter=<pattern> Specifies a wildcard pattern that folder names must match to be included in the generated list (without this, all folders are included).
Example: Go C:\Work FOLDERCONTENT="dirfilter=~(.svn)"
If you need a comma (,) character within the pattern, put embedded quotes around the pattern, similar to the filefilter examples above.
maxfiles=<num> Specify the maximum number of files to list at each level. If menus for sub-folders are generated, each menu is limited in a similar way.
Example: Go C: FOLDERCONTENT="maxfiles=5,sortdate"
If you wish to exclude files entirely, it is more efficient to use nofiles rather than maxfiles=0.
maxdirs=<num> Specify the maximum number of directories to list at each level. If menus for sub-folders are generated, each menu is limited in a similar way.
Example: Go C: FOLDERCONTENT="maxdirs=10"
If you wish to exclude directories entirely, it is more efficient to use nodirs rather than maxdirs=0.
maxdepth=<levels> Specify the maximum number of levels deep that sub-folders can be expanded in the generated list.
Example: Go C: FOLDERCONTENT="maxdepth=10"
maxwidth=<width> Specifies a maximum width (in characters) for each item in the list. If the folder contains items with wide names, you may want to use this to stop the list from being too wide. If not specified, no maximum is used by default.
Example: Go C:\Windows\System32 FOLDERCONTENT="maxwidth=30,maxdepth=10"
hideext Do not show the filename extensions for files in the generated list.
Example: Go /mydocuments FOLDERCONTENT=hideext
sortext Sorts files in the generated list by file extension.
Example: Go /temp FOLDERCONTENT=nodirs,sortext
sortsize Sorts files in the generated list by size.
Example: Go "C:\Program Files" FOLDERCONTENT=sortsize
sortdate Sorts files in the generated list by timestamp.
Example: Go /downloads FOLDERCONTENT=sortdate
sortnone Do not sort the list at all. Files and folders will still be grouped but, within each group, they will be displayed in the order the operating system returned them. Often be the same as sorting by name, but can result in special or random orders in some folders.
Useful with the Quick Access folder (renamed Home in later versions of Windows 11), where the order is something you define and usually want preserved anywhere the items are displayed.
Example: Go /quickaccess FOLDERCONTENT=norecurse,nofiles,sortnone
sortnumeric Alphabetical sort with special handling for numbers, e.g. "2abc" will sort before "10abc".
Example: Go /downloads FOLDERCONTENT=sortnumeric
sortreverse Reverse the normal sort order of items in the generated list.
Example: Go /downloads FOLDERCONTENT=sortdate,sortreverse
copy The generated list is dedicated to copying selected files to the folders shown in the list. This modifies the standard behaviour when you select a sub-folder from the drop-down menu. For example, if you select some files in the current folder, and then choose a sub-folder from the drop-down Go FOLDERCONTENT menu, the files would be copied to that folder.
Each generated button will run the Copy command. You can use the separate COPYARGS argument to specify additional Copy-command arguments which are included in each generated button.
Example: Go \\NAS\Music FOLDERCONTENT=nofiles,copy
move Selecting a sub-folder from the generated list will move selected files to that folder.
Example: Go D:\Archive\Documents FOLDERCONTENT=nofiles,move
copytosource Clicking a file or folder in the generated list will copy it into the current folder. (Note that this copy is in the opposite direction to the copy and move modes discussed just above.)
This could be useful if you have a folder containing template items which you frequently need to copy into different folders as you move around. To update the list of template items, you would just need to add or remove things (or softlinks to them) to the folder.
Example: Go "C:\My Templates" FOLDERCONTENT=copytosource
There are no separate "move" versions of the "copyto…" keywords, since it seems unlikely they'd be needed, but you can achieve the same thing via the COPYARGS argument:
Example: Go C:\ FOLDERCONTENT=copy COPYARGS MOVE
copytodest Similar to copytosource, except the item you click will be copied to the destination folder rather than the current (source) folder.
Example: Go "C:\Templates" FOLDERCONTENT=copytodest,nodirs
copytoleft Similar to copytosource, except the item you click will always be copied to the left folder (assuming a dual-display window).
Example: Go "C:\Templates" FOLDERCONTENT=copytoleft
copytoright Similar to copytosource, except the item you click will always be copied to the right folder (assuming a dual-display window).
Example: Go "C:\Templates" FOLDERCONTENT=copytoright
useshell Normally folder paths like C:\ are enumerated using the native Windows API functions. If you specify the useshell keyword, they'll instead be enumerated using the shell (i.e. Explorer). This may give you localized names in some cases, as well as different ordering and different contents.
Example: Go C: FOLDERCONTENT=useshell
embeddedcmddirs If an embedded command is specified, applies it to directories as well as files. Otherwise, the embedded command is only applied to files and clicking directories will navigate to them normally.
Example:
Go /home FOLDERCONTENT=embeddedcmddirs
[Copy ARCHIVE=7z TO /desktop CREATEFOLDER "{o|noext}_Backup"]
FORMATPATH /S
(no value) Reads the path that the current folder format was set for (if any).
Example: Go FORMATPATH
FORWARD /S
(no value) Navigate to the next folder in the history list.
Example: Go FORWARD
FORWARDLIST /O
(no value) Display a list of all subsequent folders in the history list (acts as a dynamic button). This is used on the drop-down menu attached to the Forward button on the default toolbar.
Example: Go FORWARDLIST
Example: Go FORWARDLIST=namesonly
Example: Go FORWARDLIST=noicons
Example: Go FORWARDLIST=noicons,keys
Example: Go FORWARDLIST=sort
Note that because this parameter requires an equals sign, you must enclose the whole value of the FORWARDLIST argument in quotes.
Example: Go FORWARDLIST="sort,maxwidth=25"
FROMSEL /S
(no value) Indicates the first selected folder in the source file display. This argument is used to open the selected folder (in the current file display, another tab, a new Lister, etc).
Example: Go FROMSEL NEW
FTP /S
(no value) Displays the FTP Connect dialog, allowing you to make an ad-hoc connection to an FTP site.
Example: Go FTP
FTPCMD /K/R
<command> Sends a raw command to the remote FTP server (when currently viewing an FTP directory). If no FTP site is currently connected the command has no effect. The effects of the command, if any, can be viewed in the FTP log.
Example: Go FTPCMD chmod * 755
FTPSITE /K
<site name> Connect to an FTP site listed in the FTP address book. The site must be specified by name, and if the site is in a sub-folder of the address book you must include the complete path of the entry. The FTPSITE argument is the equivalent of prefixing the site entry name with @ in the PATH argument.
Example: Go FTPSITE "Work Servers\Dallas\Production"
FTPSITEICONS /S
(no value) In conjunction with the FTPSITELIST argument, displays icons for all sites in the list generated by the command.
Example: Go FTPSITELIST FTPSITEICONS
FTPSITELIST /O
(no value) Displays a list of the sites in the FTP address book(acts as a dynamic button).
<site prefix> Displays the FTP site list starting from a specified sub-folder of the address book.
Example: Go FTPSITELIST "Work Servers"
GROUPCOLLAPSE /K
<group name> When the file display is grouped, this command can be used to collapse a specified group. The group name must match exactly, but you can also use a wildcard pattern to collapse all groups matching that pattern.
Example: Go GROUPCOLLAPSE *
GROUPEXPAND /K
<group name> Expand a specified file group. The group name must match exactly, but you can also use a wildcard pattern to expand all groups matching that pattern.
Example: Go GROUPEXPAND *
HEADING /O
(no value) When used with commands which generate a list of items (see dynamic buttons), the HEADING argument adds a small heading at the start of the list. The heading will be hidden when the list is empty. Headings only happen for commands which potentially generate multiple items at the same level as the button itself.
When HEADING is used by itself, without specifying a text value, the main button's label text is used for the heading.
Example: Go DRIVEBUTTONS HEADING
<heading text> You can specify the heading text if you want it to be different to the button's label.
Example: Go DRIVEBUTTONS HEADING="List of Drive Buttons"
HISTORYLIST /O
(no value) Display the contents of the history list (acts as a dynamic button). This is a combination of the previous (BACKLIST) and subsequent (FORWARDLIST) folders.
Example: Go HISTORYLIST
Example: Go HISTORYLIST=namesonly
Example: Go HISTORYLIST=noicons
Example: Go HISTORYLIST=noicons,keys
Example: Go HISTORYLIST=sort
Note that because this parameter requires an equals sign, you must enclose the whole value of the HISTORYLIST argument in quotes.
Example: Go HISTORYLIST="sort,maxwidth=25"
HOMEDIR /O
(no value) Reads the home directory (configured via the Home Folder Preferences page).
Example: Go HOMEDIR
update Updates the home directory setting to the folder in the current source file display.
Example: Go HOMEDIR=update
reset Resets the home directory setting to the defaults (first folder in each tab, rather than a specific folder).
Example: Go HOMEDIR=reset
INITIALDIR /S
(no value) Returns the file display to the very first folder that it read.
Example: Go INITIALDIR
KEYARGS /K/M
<qualifier:arguments> … Provides an alternate way to modify the behaviour of the Go command depending on which qualifier keys are held down (instead of using the @keydown command modifier). This is a multiple value argument - for each qualifier key combination listed, you can define a separate set of arguments that will be used when command is run and that key combination is held.
For example, you could configure a Go button to open a folder in a new tab by default, but in a new Lister if the Ctrl key were held down.
The qualifier part of the value consists of one or more keywords that represent the qualifier keys - ctrl, shift and alt. These can be combined, for example ctrlshift means that both the Ctrl and Shift keys must be held down. You can also use the keyword none to indicate arguments that are applied when no qualifiers are held.
Example: Go FROMSEL KEYARGS "ctrl:NEW" "none:NEWTAB=findexisting"
When generating dynamic lists via Go DRIVEBUTTONS, Go FOLDERCONTENT or Go FTPSITELIST, you can also specify mmb as a qualifier to override the normal behavior where middle-clicks open folders in new tabs. The example below shows a list of drive buttons where middle-clicking one will open it in a new window instead of a new tab:
Example: Go DRIVEBUTTONS KEYARGS "mmb:NEW"
If you specify actions for both ctrl and mmb, the Simulate middle mouse click with Ctrl + left click option in Toolbar Preferences will be ignored for the button; i.e. Ctrl + left click will run the ctrl action not the mmb action.
(While you can also use mmb with simple Go commands that take you to one specific folder, you may find Multiple Function Button better for those, since lets you assign independent commands to the left, middle and right mouse buttons.)
LASTACTIVELISTER /S
(no value) Brings the most recently active Lister to the front. If there is no valid Lister currently open, any other arguments provided to the command are used instead. So for example, you could have a global hotkey that brings the previous Lister to the front, or opens a new one if no Lister is open.
Example: Go LASTACTIVELISTER NEW
LASTCRUMB /S
(no value) If the file display has a breadcrumbs location field associated with it, and a ghost path is currently shown, this command will go to the last "crumb" in the ghost path.
Example: Go LASTCRUMB
LAYOUT /K
<layout name> Opens the folder in a new Lister loaded from the specified layout. If the layout contains more than one Lister, only the first Lister is used. The other arguments of the Go command can be used to override the settings in the layout.
Example: Go FROMSEL LAYOUT=Pictures VIEW=details
NAME /K
<name> Specifies a name to save or load the folder tree expansion. Use with REMEMBERTREEEXPANSION and RESTORETREEEXPANSION.
Example: Go REMEMBERTREEEXPANSION NAME=CurrentJob
NETPASS /K
<password> Provide the password to make a connection to a network resource. In conjunction with NETUSER this lets you connect to a network share without having to enter your credentials manually.
Example: Go \\server\share NETUSER=username NETPASS=password
NETPROMPT /S
(no value) Forces the password prompt to be shown when connecting to a network resource even if a username and password are specified with the NETUSER and NETPASS arguments. The values given will be used as the defaults in the password prompt, allowing you to edit them before making the connection.
Example: Go \\server\share NETUSER=username NETPROMPT
NETUSER /K
<username> Provide the username to make a connection to a network resource. You can also provide the password if needed using NETPASS.
NEW /O
(no value) Opens a new Lister. The Default Lister settings are used for the newly opened Lister, although the various other arguments for the Go command can be used to override the settings of the Default Lister.
Example: Go C:\ NEW
<x>,<y>,<w>,<h> Specify the position and size of the new Lister window. <x> and <y> represent the left and top edge coordinates of the window, and <w> and <h> the width and height.
Example: Go NEW 240,300,640,480
max Maximize the new Lister window. You can use the <x> and <y> parameters to control which monitor the window appears maximized on.
Example: Go NEW -1024,0,max
min Minimize the new Lister window. If a size and position is specified as well, it will represent the restored position once you un-minimize (restore) the Lister.
Example: Go NEW 1800,50,1024,768,min
norm The new Lister window is to be neither minimized nor maximized. Use this to override if the Default Lister is maximized, for example.
Example: Go NEW norm
source Set the new Lister to be the current source.
Example: Go FROMSEL NEW=source
dest Set the new Lister to be the destination.
Example: Go C:\Backup NEW=dest
lockoff The new Lister will be set as "off" - neither source nor destination.
Example: Go NEW=off
tree Opens the folder tree in the new Lister.
Example: Go C:\Windows NEW=tree
notree Does not open the folder tree in the new Lister.
Example: Go NEW=0,0,640,480,notree
dual Open the new Lister in dual-display mode, taking the vertical or horizontal layout from the Default Lister.
Example: Go NEW=dual C:\ DUALPATH D:\
dualhoriz Opens the new Lister in dual-display mode, laid out horizontally.
Example: Go NEW=dualhoriz FROMSEL
dualvert Open the new Lister in dual-display mode, laid out vertically.
Example: Go NEW=dualvert C:\ DUALPATH D:\
nodual Opens the new Lister in single-display mode.
Example: Go NEW=nodual
viewpane Displays the viewer pane in the new Lister.
Example: Go NEW=viewpane
noviewpane Does not display the viewer pane in the new Lister.
Example: Go NEW=noviewpane,notree
findpanel Displays the utility panel in Find Files mode in the new Lister. The panel will open in its Simple or Advanced state, depending on which was used the last time the panel was closed.
Example: Go CURRENT NEW=findpanel
findsimple Displays the utility panel in Find Files (Simple) mode in the new Lister.
Example: Go CURRENT NEW=findsimple
findadvanced Displays the utility panel in Find Files (Advanced) mode in the new Lister.
Example: Go CURRENT NEW=findadvanced
syncpanel Displays the utility panel in Synchronize mode in the new Lister.
Example: Go {sourcepath} DUALPATH {destpath} NEW=syncpanel
dupepanel Displays the utility panel in Duplicate File Finder mode in the new Lister.
Example: Go {sourcepath} NEW=dupepanel
noutilitypanel Do not display the utility panel in the new Lister.
Example: Go NEW=noutilitypanel
metapane Displays the metadata pane in the new Lister.
Example: Go NEW=metapane
nometapane Does not display the metadata pane.
Example: Go NEW=nometapane,noutilitypanel,noviewpane,notree,nodual
NEWTAB /O
(no value) Opens a new folder tab. If no path is specified (e.g. via the PATH argument) then an empty tab is opened, otherwise the specified path will be loaded into the new tab. You can use the TABPOS argument to control where the newly-opened tab is positioned.
Example: Go C:\ NEWTAB
deflister If the command is run without a Lister then the Default Lister will open along with a new tab for the specified folder. If a Lister already exists then a new tab for the specified folder will open normally in the existing Lister.
Example: Go C:\ NEWTAB=deflister,findexisting
dupe Create the new tab as a duplicate of the existing tab (similar to TABDUPLICATE=full).
Example: Go NEWTAB=dupe
findexisting Look for the specified path in existing tabs. If found, the existing tab will be brought to the front; otherwise a new tab will be opened. The active tab is checked first, and nothing will happen if the active tab already displays the specified path.
Example: Go CURRENT NEWTAB=findexisting OPENINDUAL
In some situations, findexisting is the default behavior, and nofindexisting can be used to suppress it.
findinactive Like findexisting, except that if the active tab already has the specified path then a new tab will be opened. Intended for buttons which switch to existing tabs to reduce clutter while retaining the ability to open a second tab for the same folder when needed.
Example: Go "C:\Program Files" NEWTAB=findinactive
nofindexisting Explicitly suppresses the findexisting behavior described above. The default for most commands it to not look for existing tabs, but some (e.g. Go OPENCONTAINER NEWTAB) will look for existing tabs unless explicitly told not to.
Example: Go OPENCONTAINER NEWTAB=nofindexisting
nofocus The new tab will not be made active.
Example: Go CURRENT NEWTAB=nofocus
tofront Brings the Lister to the front. This is useful when opening a tab in another window.
Example: Go CURRENT NEWTAB=tofront OPENINDEST
NEXTCRUMB /S
(no value) If the file display has a breadcrumbs location field associated with it, and a ghost path is currently shown, this command will go to the next "crumb" in the ghost path.
Example: Go NEXTCRUMB
NOSCRIPT /S
(no value) Allows a script to run Go commands without triggering other scripts (or itself). Adding the NOSCRIPT argument disables the OnBeforeFolderChange, OnAfterFolderChange, OnOpenTab and OnOpenLister events that would otherwise be triggered by the command.
OPENCONTAINER /O
(no value) Opens the container (parent folder) of the selected item. In normal folders this is not that useful (since the parent of the selected item is the folder you're already in), but in file collections, libraries and flat view it lets you quickly go to the actual folder where a file is located.
This command also works when multiple items are selected and may cause multiple windows or tabs to open if the selected items come from multiple containers.
This command is used on the default collection item context menu.
When combined with the NEWTAB argument, existing tabs are searched for automatically, without having to explicitly use NEWTAB=findexisting. If you want a new tab to open all the time, ignoring any existing tabs for the same folder, then you can use NEWTAB=nofindexisting.
target Dereferences a shortcut or junction. This is similar to the Find Target button in the system Properties dialog for shortcuts. When you run this command with a shortcut selected, the folder containing the target of the shortcut will be loaded and the target itself will be automatically selected (unless noselect is also given; see below). Similarly, if a junction is selected, you'll be taken the parent of its target and its target will be selected. If the selected item is neither a shortcut nor a junction then the command functions the same as if target had not been specified.
Example: Go OPENCONTAINER=target NEW
noselect Normally, the item or items in question are selected and made visible in the containing folder. Specifying this argument prevents the selection and just opens the containing folder.
Example: Go OPENCONTAINER=target,noselect NEWTAB
OPENINDEST /S
(no value) The specified folder will be read into the destination file display. If the current Lister is not in dual-display mode, then it could mean the folder is read into another Lister altogether. You can combine this with NEWTAB to open tabs in the destination.
Example: Go CURRENT OPENINDEST
OPENINDUAL /O
(no value) The specified folder will be read into the destination file display in a dual-display Lister. The difference between this argument and OPENINDEST is that this will force a single-display Lister into dual-display mode if it is not in that mode already. The default layout (horizontal or vertical) will be used in this case.
horiz Force the layout of the dual-display Lister to horizontal (one display above the other).
Example: Go C:\Windows OPENINDUAL=horiz
vert Force the layout to vertical (side-by-side displays).
Example: Go CURRENT NEWTAB OPENINDUAL=vert
OPENINLEFT /S
(no value) Reads the specified folder into the left-hand (or top) file display in a dual-display Lister. In a single-display Lister, this argument has no effect (the folder will be read into the single display as normal).
Example: Go {rightpath} OPENINLEFT
OPENINRIGHT /O
(no value) Reads the specified folder into the right-hand (or bottom) file display in a dual-display Lister. If the current Lister is not already in dual-display mode it will be set to that mode automatically. The default layout (horizontal or vertical) will be used in this case.
Example: Go {leftpath} OPENINRIGHT
Example: Go C:\Windows OPENINRIGHT=horiz
Example: Go {leftpath} NEWTAB OPENINRIGHT=vert
PATH
(no value) Specify the path to read (or in conjunction with the FOLDERCONTENT argument, the path to display the contents of).
Opus supports paths in many formats, for example:
  • An absolute path like C:\Windows
  • A relative path like ..\.. (goes up two levels from the current folder)
  • A virtual filesystem URL-style path (e.g. ftp://ftp.microsoft.com or lib://Documents)
  • An FTP address-book shortcut (e.g. @MyFtpSite)
  • A folder alias like /mydocuments
  • An environment variable like %USERPROFILE%
  • An external control code like {sourcepath}
  • A file URI like file:///C:/Temp. This is the default argument for the Go command and so you do not need to specify the PATH keyword. Remember that if the path contains spaces it needs to be enclosed in quotes.
Example: Go "C:\Program Files\GPSoftware\Directory Opus"
PATHENTRY /O
(no value) Displays the find-as-you-type field in a special mode ("go" mode) that lets you navigate to another folder in the current file display. This command is equivalent to CLI QUICKGO.
Example: Go PATHENTRY
dest The "Go" field will act on the destination file display rather than the source. Note that it will still appear at the bottom of the source file display, but once you press Enter the folder will be read into the destination.
Example: Go PATHENTRY=dest
left The "Go" field will act on the left-hand file display, whether it is the source or destination.
Example: Go PATHENTRY=left
right The "Go" field will act on the right-hand file display.
Example: Go PATHENTRY=right
REBUILDTREE /O
(no value) Rebuilds the contents of the folder tree attached to the source file display. This is the equivalent of turning the tree off and then back on again.
Example: Go REBUILDTREE
dest Rebuilds the folder tree attached to the destination file display (when dual trees are enabled).
Example: Go REBUILDTREE=dest
left Rebuilds the folder tree attached to the left/top file display.
Example: Go REBUILDTREE=left
right Rebuilds the folder tree attached to the right/bottom file display (when dual trees are enabled).
Example: Go REBUILDTREE=right
both Rebuilds both folder trees (or the single tree, whichever is applicable).
Example: Go REBUILDTREE=both
REFRESH /O
(no value) Refresh the display of the current folder in the source file display.
Example: Go REFRESH
tree Refresh the folder tree.
Example: Go REFRESH=tree
both Refresh both file displays in a dual-display Lister.
Example: Go REFRESH=both
all Refresh both file displays and folder trees.
Example: Go REFRESH=all
source Refresh the source file display and its tree.
Example: Go REFRESH=source
dest Refresh the destination file display and its tree.
Example: Go REFRESH=dest
viewpane Refresh the viewer pane. The image or file currently displayed in the pane will be reloaded.
Example: Go REFRESH=viewpane
left Refresh the left-hand file display.
Example: Go REFRESH=left
right Refresh the right-hand file display.
Example: Go REFRESH=right
expanded Preserves expanded folders when refreshing a file display. Overrides the Preferences setting.
Example: Go REFRESH=expanded
noexpanded Collapses expanded folders when refreshing a file display. Overrides the Preferences setting.
Example: Go REFRESH=both,noexpanded
filterclear Clears any Quick Filter when refreshing. This is the same as turning on Clear the filter automatically when changing folders without affecting other commands and methods of reading folders.
Example: Go REFRESH=filterclear
filterkeep Preserves any Quick Filter when refreshing, even if Clear the filter automatically when changing folders is on.
Example: Go REFRESH=filterkeep
state Causes things like file selections and scroll position to be remembered when the folder is refreshed. Note that expanded folder state is not remembered by default - this can be enabled by adding the expanded keyword, or turning on the option in Preferences. If expanded folder state is remembered then the other state elements are also remembered automatically - so the state keyword is only effective if folder expansion is not being remembered.
Example: Go REFRESH=state
groupstate Remembers file group expansion states when refreshing. This lets you override the Preserve group expansion state on refresh Preferences option.
Example: Go REFRESH=source,groupstate
nogroupstate Does not remember file group expansion states when refreshing. This lets you override the Preserve group expansion state on refresh Preferences option.
Example: Go REFRESH=nogroupstate
REFRESHTHUMBS /O
(no value) Refreshes thumbnails displayed in the current folder. If thumbnail caching is enabled the cache for the current folder is cleared, forcing thumbnails to be regenerated.
Example: Go REFRESHTHUMBS
shift Refreshes thumbnails only if the Shift key is held down. This lets you combine a normal folder refresh with a thumbnail refresh on the one command - it could perform an ordinary folder refresh by default, and also force the regeneration of thumbnails with the Shift key held down.
Example: Go REFRESH REFRESHTHUMBS=shift
alt Refresh thumbnails only if the Alt key is held down.
Example: Go REFRESHTHUMBS=alt
ctrl Refresh thumbnails only if the Control key is held down.
Example: Go REFRESHTHUMBS=ctrl REFRESH=all
REMEMBERTREEEXPANSION /O
(no value) Remembers the current expansion state of the source folder tree. Once the state has been remembered, you can restore it later on with RESTORETREEEXPANSION.
By default the expansion state is just remembered for the lifetime of the Lister. If used with the NAME argument the expansion will be saved under that name and can be restored at any time in the future.
dest Remembers the expansion state of the folder tree attached to the destination file display (when dual trees are enabled).
Example: Go REMEMBERTREEEXPANSION=dest
left Remembers the expansion state of the folder tree attached to the left/top file display.
Example: Go REMEMBERTREEEXPANSION=left
right Remembers the expansion state of the folder tree attached to the right/bottom file display (when dual trees are enabled).
Example: Go REMEMBERTREEEXPANSION=right
both Remembers the expansion state of both folder trees (or the single tree, whichever is applicable).
Example: Go REMEMBERTREEEXPANSION=both
RESTORETREEEXPANSION /O
(no value) Restores the expansion state of the source folder tree that was previously remembered with REMEMBERTREEEXPANSION.
Combine with the NAME argument to restore a saved expansion.
Example: Go RESTORETREEEXPANSION NAME=CurrentJob
dest Restores the expansion state of the folder tree attached to the destination file display (when dual trees are enabled).
Example: Go RESTORETREEEXPANSION=dest
left Restores the expansion state of the folder tree attached to the left/top file display.
Example: Go RESTORETREEEXPANSION=left
right Restores the expansion state of the folder tree attached to the right/bottom file display (when dual trees are enabled).
Example: Go RESTORETREEEXPANSION=right
both Restores the expansion state of both folder trees (or the single tree, whichever is applicable).
Example: Go RESTORETREEEXPANSION=both
reset Resets the expansion of the tree to its initial state. Can be combined with the above keywords.
Example: Go RESTORETREEEXPANSION=both,reset
ROOT /O
(no value) Navigate to the root of the current folder. For example, the root of C:\Program Files\GPSoftware\Directory Opus is C:.
Example: Go ROOT
collapse Collapses the current drive's branch in the folder tree at the same time as navigating to the root folder.
Example: Go ROOT=collapse
RUNEMBEDDEDIFNOTFOUND /S
(no value) This argument is used when embedding a function in the Go FINDTITLE command. Normally the embedded function will not be run if no Listers exist that match the supplied string. If the RUNEMBEDDEDIFNOTFOUND argument is specified, the embedded command will be run in the current Lister if a matching Lister is not found.
Example:
Go FINDTITLE PhotoWork RUNEMBEDDEDIFNOTFOUND
[Set VIEW=Thumbnails]
SETFOCUS /S
(no value) If the Go command reads a folder into the non-active side, this argument makes that side active (gives it the focus). You can combine this with commands that generate other buttons like Go DRIVEBUTTONS.
Example: Go DRIVEBUTTONS=multifunc SETFOCUS
SWAP /S
(no value) Swaps the folders displayed in the source and destination file displays.
Example: Go SWAP
SWITCHPATH /K/M
<alternate path> … Switches between (or cycles through) two or more paths. The PATH argument is used to provide the first path in the sequence, and then the SWITCHPATH argument provides the second and subsequent paths. When you run this command, Opus looks at the current path shown in the source file display. If it matches one of the provided paths, the next path in the sequence is read (and then the next, and then the next, and so on). If the current path does not match one of the provided ones the first path in the sequence is read.
Example: Go C:\ SWITCHPATH D:\ E:\ F:\ G:\
TABCLOSE /O
(no value) Close the current folder tab in the source file display.
You can combine this with the PATH argument to specify the path of a tab that should be closed. When used in this context the PATH argument can accept wildcards - all tabs matching the supplied pattern will be closed.
The TABPOS argument can be used to specify the index (starting from 0) of a specific tab to close, or position relative to the current tab, or the position of the first or last tab. (The PATH argument can also be given a specific tab index, but this usage is deprecated in favor of TABPOS.)
Examples: Close the current tab: Go TABCLOSE
Close all tabs showing a drive on C: Go TABCLOSE PATH=C:\*
Close the first tab: Go TABCLOSE TABPOS=first
Close the last tab: Go TABCLOSE TABPOS=last
Close the tab after the current tab: Go TABCLOSE TABPOS=+1
Close the tab before the current tab: Go TABCLOSE TABPOS=-1
When used from a script, you can pass the default value of a Tab object to specify the tab you wish to close.
Example: Go TABCLOSE=<tab>
left Close a folder tab in the left (or top) file display, irrespective of whether it is the source or not.
Example: Go TABCLOSE=left
right Close a folder tab in the right (or bottom) file display.
Example: Go TABCLOSE=right TABPOS=-2
dest Close a folder tab in the destination file display.
Example: Go TABCLOSE=dest PATH=C:\*
force Close the folder tab even if it is locked and closing individual locked tabs is disabled in Preferences.
Example: Go TABCLOSE=force
Example: Go TABCLOSE=dest,force
TABCLOSEALL /O
(no value) Close all folder tabs except the current one.
When combined with the TABGROUPLOAD command, this overrides the tab group's Close existing Folder Tabs setting, and forces existing tabs to be closed.
Example: Go TABCLOSEALL
left Close all folder tabs to the left of the current tab.
Example: Go TABCLOSEALL=left
right Close all folder tabs to the right of the current tab.
Example: Go TABCLOSEALL=right
dest Lets you close tabs in the destination file display in a dual-display Lister.
Example: Go TABCLOSEALL=dest,right
force Forces locked tabs to be closed. Normally locked tabs are not closed by this command.
Example: Go TABCLOSEALL=right,force
expand Expands tabs to Listers. The tabs will be closed in the current Lister, and each folder opened as a new Lister.
Example: Go TABCLOSEALL=right,expand
no When combined with the TABGROUPLOAD command, this overrides the tab group's Close existing Folder Tabs setting, and forces existing tabs to be retained.
This value has no meaning when not used in conjunction with TABGROUPLOAD.
Example: Go TABGROUPLOAD=MyTabs TABCLOSEALL=no
TABCOLOR /K
<color> Assigns a custom color to the current tab. You can specify the color in the decimal form R,G,B (e.g. 127,192,55) or the hex form #RRGGBB (e.g. #ff0033).
Example: Go TABCOLOR #ff8000
reset Resets the current tab's color.
Example: Go TABCOLOR=reset
edit Initiates editing of the current tab's color. You can use the PATH argument to specify the index of a tab to edit (with the left-most being index #0).
Example: Go TABCOLOR=edit
TABDUPLICATE /O
(no value) Duplicates the current folder tab.
Example: Go TABDUPLICATE
active Makes the new tab active.
Example: Go TABDUPLICATE=active
dual Creates a duplicate of the current folder tab in the other file display of a dual-display Lister.
Example: Go TABDUPLICATE=dual
full Creates a full duplicate including file selections and sub-folder expansion.
Example: Go TABDUPLICATE=full
nocolor Doesn't copy the tab's color settings when the duplicate is made.
Example: Go TABDUPLICATE=dual,nocolor
nolock Doesn't copy the tab's lock state when the duplicate is made.
Example: Go TABDUPLICATE=full,nolock
TABGROUPDESC /K
<description> When saving a tab group programmatically using Go TABGROUPSAVE, this lets you assign a description to the tab group at the same time.
Example: Go TABGROUPSAVE=MyTabs TABGROUPDESC="All my lovely tabs"
TABFINDEXISTING /S
(no value) If the specified folder is open in another tab Opus will switch to that tab, otherwise the folder will be read into the current tab. Enables similar behavior to the NEWTAB=findexisting argument, except that a new tab is not opened if the path is not found.
Example: Go /mydocuments TABFINDEXISTING
TABGROUPFORCE /S
(no value) Use in conjunction with the TABGROUPLOAD or TABGROUPLIST arguments to force folders in the loaded tabs to load immediately even if they would normally be blocked by the Auto-Loading settings on the Automatic Reading page in Preferences.
Example: Go TABGROUPLOAD "My Tab Group" TABGROUPFORCE
TABGROUPLIST /O
(no value) Displays a list of your saved Folder Tab Groups (acts as a dynamic button). Selecting a group from the list will open those tabs in the current file display.
This argument works when used in conjunction with the USEQUALKEYS, TABGROUPFORCE and KEYARGS arguments.
Example: Go TABGROUPLIST
keys Assigns the accelerator keys 0 through 9 to the first ten items displayed on the generated tab group list.
Example: Go TABGROUPLIST=keys USEQUALKEYS
icons Displays icons for items on the generated tab group list.
Example: Go TABGROUPLIST=keys,icons
nohighlight Prevents the active tab group from being highlighted.
Example: Go TABGROUPLIST=icons,nohighlight
savecurrent Saves the current folder tab group (if any) before loading a new one. Without this, any changes to a tab group will be lost when loading another one, unless you explicitly save them.
As a special case, clicking the button for the current tab group will reload that group without first saving over it, giving you a way to reset to the group's last saved state.
If no tab group is currently loaded, nothing will be saved before loading the new tab group.
Example: Go TABGROUPLIST=savecurrent
Note that if you want Opus to save tab groups automatically in this way, you may also want to add something to trigger Go TABGROUPSAVE=!current,!quiet when listers close, or on other events such as opening/closing tabs or changing folders, depending on when you want the tab group to be updated. This probably also only makes sense if you only use one lister, since multiple listers may have differnet views of the currently open groups and save over each other. But if you want auto-saving tab groups, you're probably already using a single window all the time, as other people would use separate windows for separate tab groups and switch between windows instead of switching groups in a single window.
TABGROUPLOAD /K
<group name> Loads the named folder tab group. This can be combined with OPENINDUAL etc. to open the tab group in another file display. You can also combine the TABCLOSEALL argument to override the tab group's Close existing Folder Tabs setting.
Example: Go TABGROUPLOAD "My Tab Group" TABCLOSEALL=no
TABGROUPSAVE /O
(no value) Save the current set of folder tabs as a new tab group. You will be prompted to provide a name for the group.
<group name> Save the current set of folder tabs using the specified group name.
Example: Go TABGROUPSAVE "My Tab Group"
!both In a dual-display Lister, this will save the tabs from both file displays to a single group using the "specific sides" option. You can also specify a group name by following the keyword with a comma. (The group name, if any, must come after the keyword and not before.)
Example: Go TABGROUPSAVE="!both,My Tab Group"
!closeall Saves the tab group such that it will close all existing tabs when it is loaded (unless overridden at the time of loading). If neither !closeall nor !nocloseall are specified, saving over an existing group will preserved its mode, new groups created non-interactively will close existing tabs by default, and new groups created interactively will default to the mode used the last time the interactive dialog was displayed. (The group name, if any, must come after the keyword and not before.)
Example: Go TABGROUPSAVE="!both,!closeall,My Tab Group"
!nocloseall Saves the tab group such that it will not close any existing tabs when it is loaded (unless overridden at the time of loading). See !closeall, above, for more information. (The group name, if any, must come after the keyword and not before.)
Example: Go TABGROUPSAVE="!both,!nocloseall,My Tab Group"
!current Saves over the folder tab group which was last loaded. The !both keyword is ignored, and instead the mode is inherited from the existing group. Add the !quiet keyword to make the command do nothing if there is no current tab group to save over; otherwise you will be prompted for the name of a new group in that situation.
Example: Go TABGROUPSAVE="!current"
!quiet Combine !quiet with !current to prevent being asked to name a new tab group if there isn't one to save over.
Example: Go TABGROUPSAVE="!current,!quiet"
!unless Combine !unless with !current to tell the command to save the current group unless it has a particular name. You probably won't need to use this directly, but it is how the Go TABGROUPLIST=savecurrent command avoids saving over the current group if you click its button to reload it.
Example: Go TABGROUPSAVE="!current,!quiet,!unless,My Tab Group"
!forget Tells the file display to forget the name of the last tab group it loaded. Combine with !both to make both sides of a dual-display lister forget. You may wish to use this if you load a tab group and then modify it to the point that it no longer has any connection to the original group, and you do not want it to remain selected in any tab group lists.
Example: Go TABGROUPSAVE="!forget"
TABLINK /K
on In a dual-display Lister, links the current active tab in the source file display with the current active tab in the destination file display.
Example: Go TABLINK=on
off If the currently active tab is linked, this will unlink it.
Example: Go TABLINK=off
toggle Toggles tab linking on or off for the currently active tabs in both left and right file displays.
Example: Go TABLINK=toggle
navlock Use in conjunction with on or toggle to specify that the tab is to be linked in navigation lock mode (so that it follows the other tab whenever the folder is changed).
Example: Go TABLINK=toggle,navlock
reset When two tabs are linked in navigation lock mode, the reset keyword lets you reset the sync position to the current locations (for recovering when they get out of sync).
Example: Go TABLINK=reset
unlinkall Unlinks all linked tabs in the current Lister.
Example: Go TABLINK=unlinkall
 ,   When used from a script, you can pass the default value of two Tab objects to specify the precise tabs you wish to link. The two values must be comma-separated. If only one Tab object is specified, it will be unlinked if it is currently linked.
Example: Go TABLINK=<tab1>,<tab2>,navlock
menu Generates the standard tab link menu. This is included on the default folder tab context menu.
Example: Go TABLINK=menu
TABLIST /O
(no value) Displays a list of the currently open folder tabs (acts as a dynamic button). Selecting a tab from the list will switch to that tab. You can also drag and drop files to the items in the list to copy them to that tab's folder.
By default the tabs shown are those from the current source file display, but you can combine with the OPENINLEFT, OPENINRIGHT and OPENINDEST arguments to display tabs from other file displays.
Example: Go TABLIST
keys Assigns the accelerator keys 0 through 9 to the first ten items displayed on the generated tab list.
Example: Go TABLIST=keys
sort Sorts the tab list alphabetically (without this, the items in the list are listed in the same order as the physical tabs). The sort order is based on the folder name (or tab label).
Example: Go TABLIST=sort,keys
sortpath Sorts the tab list alphabetically, based on the full path of each folder.
Example: Go TABLIST=sortpath
icons Displays folder icons for each tab in the list.
Example: Go TABLIST=sortpath,icons
namesonly Only displays the folder name for each tab rather than the full path. Does not affect tabs which use custom labels; custom labels are always displayed as-is.
Example: Go TABLIST=sort,namesonly
maxwidth=<width> Specifies a maximum width (in characters) for each item in the list. When showing the full path of each tab, you may want to use this to stop the tab list from being too wide. If not specified, a maximum width of 50 is used by default - you can disable this (and have no maximum width at all) by specifying maxwidth=0.
Note that because this parameter requires an equals sign, you must enclose the whole value of the TABLIST argument in quotes.
Example: Go TABLIST="keys,maxwidth=70"
lockicons Icons representing each tab's lock state will be shown to the right of the label.
Example: Go TABLIST=sort,lockicons
TABLOCK /K
lock Lock the current folder tab to prevent any folder changes. Attempts to change the folder will result in a new tab being created.
Example: Go TABLOCK=lock
lockchanges Lock the current tab. Folder changes will be allowed, but the tab will revert to its original (locked) directory if it is clicked, or if the focus is moved to another tab and then back to this one. You can also use the command Go TABLOCKDIR to revert to the original directory.
Example: Go TABLOCK=lockchanges
lockreuse Lock the current tab. Attempts to change folder will result in the first already existing, unlocked tab being used to read the new directory. A new tab will be opened if there are no unlocked tabs that can be used.
Example: Go TABLOCK=lockreuse
off Unlock the current folder tab.
Example: Go TABLOCK=off
toggle Combine with the various lock keywords to toggle that lock mode on or off.
Example: Go TABLOCK=lockchanges,toggle
all Lock or unlock all folder tabs.
Example: Go TABLOCK=lock,all
left Lock or unlock all tabs to the left of the current tab.
Example: Go TABLOCK=lockchanges,toggle,left
right Lock or unlock all tabs to the right of the current tab.
Example: Go TABLOCK=off,right
target For use with scripting. Acts on the Command object's tab rather than the currently active tab.
Example: Go TABLOCK=off,target
menu Generates the standard tab lock menu. This is included on the default folder tab context menu.
Example: Go TABLOCK=menu
TABLOCKDIR /S
(no value) Indicates the original (locked) directory of the current folder tab. This is the directory that was shown in the tab when it was set to 'Lock Allow Changes' mode. You can use this to return to the locked folder, or open it in another tab or Lister. If the current tab is not locked this argument behaves the same as the CURRENT argument.
Example: Go TABLOCKDIR
TABMOVE /O
(no value) Move the current folder tab to the other file display. (See TABPOS for repositioning tabs without changing sides.) The Lister will be set to dual-display mode if it's not in that mode already.
Example: Go TABMOVE
split Splits the folder tabs currently open in a single-display Lister. The Lister will be set to dual-display mode, and all tabs from the current tab onwards will be moved to the other display. If the Lister is already in dual-display mode this command has no effect.
Example: Go TABMOVE=split
splitlister Splits the folder tabs in the current file display to a new Lister. All tabs from the current tab onwards will be closed in the current display, and reopened in a new Lister.
Example: Go TABMOVE=splitlister
<new position> Specify the new position for the moved tab. You can specify an absolute position, -1 to indicate the same relative position, and -2 to position the moved tab to the right of the currently active tab. If not specified, the moved tab will be positioned at the end of all existing tabs.
Example: Go TABMOVE=-2
active If specified, the moved tab will be made active. Otherwise the previously active tab in the other file display remains active.
Example: Go TABMOVE=active,-2
TABNAME /O
(no value) Clears the name of the current tab if one has been assigned. This will reset the tab label back to the default which is to show the name of the current folder.
Example: Go TABNAME
<tab name> Assigns the specified name to the current tab. If combined with the NEWTAB argument the name will be assigned to the newly created tab.
Example: Go C:\Work NEWTAB TABNAME "My Work Dir"
You can use several special "tokens" in the tab name to insert various pieces of information:
%Pfull path of the current (source) folder
%Nname of the current (source) folder
%Rdrive root of the current (source) folder
%!hide section
Example: Go TABNAME "%R - %N"
The %! code lets you hide sections in the string where all other tokens inside the section are empty.
Example: Go TABNAME "%!Drive %R : %!%N"
That means that if the %R token expands to an empty string, the result will be just "%N" (the name of the folder).
!edit Initiates editing of the current tab's name. You can use the PATH argument to specify the index of a tab to edit (with the left-most being index #0).
Example: Go TABNAME=!edit
TABPOS /K
first When used with the NEWTAB argument, causes the newly created tab to appear as the first on the tab bar. When used with TABCLOSE, closes the first tab. When used on its own, repositions the active folder tab so it is first on the tab bar.
Example: Go C:\ NEWTAB TABPOS=first
When used from a script, you can pass the default value of a Tab object to specify the tab you wish to reposition as the second parameter.
Example: Go TABPOS=first,<tab>
last When used with the NEWTAB argument, causes the newly created tab to appear as the last on the tab bar. When used with TABCLOSE, closes the last tab. When used on its own, repositions the active folder tab so it is last on the tab bar.
Example: Go TABPOS=last
Example: Go TABPOS=last,<tab>
+1 When used with the NEWTAB argument, causes the newly created tab to appear as to the right of the currently active tab. When used with TABCLOSE, closes the tab to the right of the active tab. When used on its own, repositions the active folder tab to the right of its current position on the tab bar. You can also use +2 for two positions to the right, and so on.
Example: Go TABPOS=+1
Example: Go TABPOS=+3,<tab>
-1 When used with the NEWTAB argument, causes the newly created tab to appear to the left of the currently active tab. When used with TABCLOSE, closes the tab to the left of the active tab. When used on its own, repositions the active folder tab to the left of its current position on the tab bar. You can also use -2 for two positions to the left, and so on.
Example: Go TABPOS=-1
Example: Go TABPOS=-2,<tab>
<index> When used with the NEWTAB argument, specifies the position for the newly created tab. When used with TABCLOSE, specifies the position of the tab to close. When used on its own, repositions the active folder tab to a specific place on the tab bar. 0 is the first tab (you can also use "first"), 1 the second, 2 the third, and so on.
Example: Go D:\ NEWTAB TABPOS=2
Example: Go TABPOS=3,<tab>
TABSCROLL /O
(no value) If there are more tabs open than will fit in the display, this command displays the tab overflow menu (useful if you want to bind this to a hotkey). You can combine this with the OPENINDEST, OPENINLEFT and OPENINRIGHT arguments to display the overflow menu in other file displays.
Example: Go TABSCROLL
<delta> Scroll the folder tabs left or right if there are more tabs open than will fit in the display.
Example: Go TABSCROLL=-1
TABSELECT /K
first Select (make active) the first folder tab in the current file display.
Example: Go TABSELECT=first
last Select the last folder tab in the current file display.
Example: Go TABSELECT=last
prev Reselect the previously selected folder tab.
Example: Go TABSELECT=prev
+1 Select the next folder tab.
Example: Go TABSELECT +1
-1 Select the previous folder tab.
Example: Go TABSELECT -1
home Resets a locked tab to its "home" directory. This is equivalent to Go TABLOCKDIR. If the current tab is not set to 'Locked Allow Changes' mode this command has no effect.
Example: Go TABSELECT home
noload Allows the active tab to be changed without triggering "auto-load on tab activation" behavior.
Example: Go TABSELECT=+1,noload
<index> Select a specific folder tab. The index is 0 relative (so Go TABSELECT 0 is equivalent to Go TABSELECT first).
Example: Go TABSELECT=5
$<tab> Select a specific folder tab from a script. If you have a Tab object and want to activate it, add it to the command string prefixed by a $ character.
Example: cmd.RunCommand("Go TABSELECT=$" + tab)
TABSWAP /O
(no value) Swaps the active tab in the left file display with the active tab in the right file display.
Example: Go TABSWAP
<index1>,<index2> Specify indices to swap a specific tab from the left file display with a specific tab in the right file display.
Example: Go TABSWAP=0,0
TABSWITCHER /O
(no value) Displays the "tab switcher", a popup list of tabs open in the current Lister. You can use it to switch to another tab in the same way Alt+Tab in Windows lets you switch to another window.
By default the tab switcher is bound to the Ctrl+Tab key; you can use this command to bind it to a different key or trigger it via a mouse button, etc.
Example: Go TABSWITCHER
taborder Displays the tab switcher with tabs listed in the same order they appear in the Lister, rather than being sorted in order of last use.
Example: Go TABSWITCHER=taborder
TABUNDOCLOSE /S
(no value) Undoes the last action that resulted in one or more tabs being closed.
Example: Go TABUNDOCLOSE
TITLE /K
<custom title> Specifies a custom title when opening a new Lister using the NEW argument. You can use several special "tokens" in the title string to insert various pieces of information:
%Dfull path of the destination folder
%Mname of the destination folder
%Gtarget if the folder is a junction or softlink
%1full path in the left file display
%2full path in the right file display
%3folder name in the left file display
%4folder name in the right file display
%Lname of the Layout the Lister came from (if any)
%Sname of the current Style selected in the Lister (if any)
%Tcomplete original title (useful for simply adding a prefix or suffix)
%!hide section
Example: Go NEW TITLE "Directory Opus - %N"
Example: Go NEW TITLE "%!%T - %!Directory Opus"
That means that if the %T token expands to an empty string, the result will be just "Directory Opus" rather than " - Directory Opus".
TOFRONT /S
(no value) Makes the Lister the active window and brings it to the front. Typically used when sending commands from outside of Opus, to make sure the window that reads the folder is visible.
Example: Go C:\ TOFRONT
TREECOLLAPSE /O
(no value) Collapses the selected branch in the tree belonging to the source file display.
Example: Go TREECOLLAPSE
dest Collapses the selected branch in the tree belonging to the destination file display (when dual trees are enabled).
Example: Go TREECOLLAPSE=dest
left Collapses the selected branch in the left/top file display.
Example: Go TREECOLLAPSE=left
right Collapses the selected branch in the right/bottom file display (when dual trees are enabled).
Example: Go TREECOLLAPSE=right
both Collapses the selected branches in both source and destination trees.
Example: Go TREECOLLAPSE=both
focus Collapses the selected branches in the tree which currently has input focus (or the tree belonging to the file display with input focus).
Example: Go TREECOLLAPSE=focus
all Collapse all folders (and all their child folders, and so on) below the selected folder, not just the selected folder.
Example: Go TREECOLLAPSE=all,both
first Collapse just the first level of descendants below the selected folder.
Example: Go TREECOLLAPSE=left,first
second Collapse the first and second levels of descendants below the selected folder.
Example: Go TREECOLLAPSE=second
full Removes all folders from the tree that aren't directly related to the current path (i.e. returning it to its default state). Only effective if the folder tree is set to not populate contents automatically.
Example: Go TREECOLLAPSE=all,full
TREEEXPAND /O
(no value) When used in conjunction with reading a folder, this command automatically expands the folder tree to display the contents of the new folder. This is only of use if the Automatically expand to current folder option on the Folder Tree / Expand / Collapse Preferences page is turned off.
You can also use this command by itself, to expand the currently selected folder.
Example: Go "C:\Program Files\GPSoftware\Directory Opus" NEW TREEEXPAND
dest Expands the selected branch in the tree belonging to the destination file display (when dual trees are enabled).
Example: Go TREEEXPAND=dest
left Expands the selected branch in the left/top file display.
Example: Go TREEEXPAND=left
right Expands the selected branch in the right/bottom file display (when dual trees are enabled).
Example: Go TREEEXPAND=right
both Expands the selected branches in both source and destination trees.
Example: Go TREEEXPAND=both
focus Expands the selected branches in the tree which currently has input focus (or the tree belonging to the file display with input focus).
Example: Go TREEEXPAND=focus
all Expand all folders (and all their child folders, and so on) below the selected folder, not just the selected folder.
Example: Go TREEEXPAND=all,both
first Expand just the first level of descendants below the selected folder.
Example: Go TREEEXPAND=left,first
second Expand the first and second levels of descendants below the selected folder.
Example: Go TREEEXPAND=second
TREESETPINSTATE /O
(no value) Toggles the "pin" state of the currently selected folder in the folder tree. Pinned folders always stay expanded - they can't be collapsed. Note that folder pinning needs to be enabled from the Pins page in Preferences for this command to have any effect.
Example: Go TREESETPINSTATE
on Turns on the "pin" state of the currently selected folder.
Example: Go TREESETPINSTATE=on
off Turns off the "pin" state of the currently selected folder.
Example: Go TREESETPINSTATE=off
UNDOCLOSELISTER /O
(no value) Reopens the last Lister that was closed (so if, for example, you accidentally close the Lister you're working with, this command would bring it back).
Example: Go UNDOCLOSELISTER
closeexisting Reopens the last Lister that was closed, and closes all other open Listers.
Example: Go UNDOCLOSELISTER=closeexisting
UP /S
(no value) Navigate up to the parent of the current folder. You can combine this with OPENINDUAL etc. to open the parent of the current folder in another file display or Lister. This can also be combined with the BACK argument - in that case, if the parent of the current folder is also the previous folder in the history list, Opus will move back rather than up - preserving the file selection and other state of the previous folder.
Example: Go UP
USEQUALKEYS /S
(no value) Activates pre-configured behaviour for the main qualifier keys - Control will open the folder in the dual-display, Shift in a new Lister and Alt in a new tab.
This is equivalent to KEYARGS ctrl:OPENINDUAL shift:NEW alt:NEWTAB.
The pre-configured behaviour can be overridden using the evaluator via the go_usequalkeys_eval Advanced Preferences option.
Example: Go C:\ USEQUALKEYS
USER /K
<user name> Can be used when certain folder aliases are supplied for the PATH argument. This lets you specify an alternative user name, to access a specific user's instance of a system folder (providing you have the appropriate permissions, of course). If the specified alias doesn't support multiple users this argument has no effect.
Example: Go /desktopdir USER="Leo Nudelson"
VIEW /K
largeicons Changes the view mode of the new folder to Large Icons mode.
Example: Go CURRENT NEWTAB VIEW=largeicons
smallicons Changes the view mode of the new folder to Small Icons mode.
Example: Go C:\ VIEW smallicons
list Changes the view mode to List mode.
Example: Go {destpath} VIEW list
details Changes the view mode to Details mode.
Example: Go CURRENT LAYOUT=PhotoLayout VIEW=details
power Changes the view mode to Power mode.
Example: Go NEW VIEW=power
thumbnails Changes the view mode to Thumbnails mode.
Example: Go /desktop VIEW=thumbnails
tiles Changes the view mode to Tiles mode.
Example: Go @WorkFTP NEWTAB VIEW tiles
WHENDUAL /K
checkmouse This works in conjunction with the BACK, FORWARD and UP arguments and is designed to be used with "app command" hotkeys like the Back button on a mouse. It lets you make navigation commands triggered from the mouse act on the file display underneath the mouse pointer in a dual display Lister, rather than, as is the default, the source file display.
Example: Go BACK WHENDUAL=checkmouse
anydevice Use with the checkmouse argument to cause the WHENDUAL argument to activate when the command is run from a non-mouse device (e.g. when the command is bound to a Back button on a keyboard).
Example: Go BACK WHENDUAL=checkmouse,anydevice
deffocus Add the deffocus argument to cause the command to fall back to the original behavior if the mouse pointer isn't currently over either of the file displays.
Example: Go BACK WHENDUAL=checkmouse,deffocus
