reference:command_reference:command_modifier_reference
The following is a list of the various command modifiers supported in toolbar buttons and hotkeys.
Description
@admin
The function requires administrator permissions. This modifier will result in a UAC prompt appearing (unless the Lister is already in administrator mode), and any external programs run by this function will be elevated.
If used by itself, this modifier affects the entire function. It can also be used to elevate a specific command rather than the entire button.
@adminelevate the entire function
@admin:notepad.exe {f}only elevates Notepad
@admin:nodisable UAC prompts for any subsequent commands in this function
@admin:yesre-enable UAC prompts for any subsequent commands
@async
The command following this modifier will be run asynchronously - Opus will not wait for it to exit before running the next command in the function (or before running this command again for the next selected file).
The default behaviour is for a function that consists of a single command to run that command asynchronously for each selected file; a function that consists of multiple commands will run each command synchronously. The default behaviour can be changed with the function_default_async option on the Miscellaneous / Advanced page in Preferences, or it can be overridden on a per-command basis with this modifier.
@async:notepad.exe {f}runs Notepad asynchronously
@codepage
Changes the code page of an MS-DOS batch command. If not specified the default code page is 1252 (Windows-1252).
@codepage:1258sets the code page to Vietnamese
@color
Allows a button's text and background colors to be changed dynamically using the evaluator. See Evaluator Button Colors for more information.
@confirm
Displays a confirmation dialog. If the user clicks the cancel button, the function is aborted at this point.
The template for this modifier is: @confirm:<message>|<positive text>|<negative text>
<message> is the text shown in the dialog, <positive text> is the text shown on the "OK" button, and <negative text> is the text shown on the "Cancel" button. These three strings are all optional - if not provided, default strings will be used. If you provide <positive text> but not <negative text> then the dialog will have an "OK" button but no "Cancel" button at all.
You can include line-breaks in the message text using the special code \n (and if you need to include a literal \n sequence in the text you must escape the \ character, as in \\n).
@confirm:Really copy files?uses default text for the OK and Cancel buttons
@confirm:Really proceed?|Oui!|Non!specifies custom text for the two buttons
@confirm:All finished|Acknowledgedcustom text for the OK button; no Cancel button at all
@ctx
Allows you to define a dynamic button using the evaluator. As a simple example,
@ctx:=return "Go DRIVEBUTTONS";
This uses the evaluator to return a simple string; functionally this is no different to simply putting the Go DRIVEBUTTONS command on a toolbar button.
As a more complex example, the default Favorites Bar toolbar uses @ctx to build the displayed favorites list, by using the Evaluator to build a command line using the current localised name of the favorites bar branch:
@ctx:=return "Favorites SHOWICONS USEQUALKEYS BRANCH=""" + LanguageStr("FavoritesBar") + """";
This uses the evaluator LanguageStr() function to retrieve the translated name of a known string, and constructs a command line using the Favorites command to display that branch of the favorites tree.
@dirsonly
The function will operate only on selected folders, ignoring any files.
@dirsonlyoperate only on directories
@disableif
The button will be disabled if the tested command is true. This is similar to the conditional testing offered by the @if modifier described below.
@disableif:Set DUAL=togglebutton will be disabled if the Lister is in dual-display mode
@disableif:!Set DUAL=togglebutton will be disabled if the Lister is NOT in dual-display mode
@disableifpath
@disableifpathr
The button will be disabled if the current source path matches the specified pattern. You can provide either an absolute path to test against, or a wildcard pattern (use @disableifpath for standard wildcards, and @disableifpathr for regular expressions). You can also use the keyword shell to test for a hosted shell namespace extension (virtual folder).
@disableifpathr:^C:\\disable command if source path is on the C: drive
@disableifpath:!*\Work\*disable unless source path is underneath a folder called Work
Paths may use aliases, environment variables, {apppath} codes, and so on, only when using wildcards (not regular expressions):
@disableifpath:!/desktopdisable unless in the Desktop folder
@disableifpath:!%SystemRoot%\System32disable unless in C:\Windows\System32 (on a typical system)
@disableifpath:{apppath|dopus.exe}disable if in the folder where Opus is installed
@disableifpath:shelldisable if in a hosted virtual folder
@disablenosel
The command will be disabled when no files or folders are selected, or optionally when no files of a certain type are selected. This is done automatically for certain standard commands and the modifier lets you make your own commands behave in a similar way. This is similar to @hidenosel.
@disablenoseldisable button when nothing is selected
@disablenosel:filesdisable button when no files are selected
@disablenosel:dirsdisable button when no folders are selected
For lister toolbars, you can use the minfiles, maxfiles and numfiles keywords to specify a minimum, maximum, or exact number of files which must be selected for the button to be enabled. Similarly, mindirs, maxdirs and numdirs can limit the number of selected folders.
@disablenosel:numfiles=2disable button unless exactly 2 files are selected
@disablenosel:maxfiles=5disable button unless 5 files or fewer are selected
@disablenosel:mindirs=3,maxdirs=5disable button unless 3, 4 or 5 folders are selected
Using the type keyword you can configure a button to be disabled unless at least one file is selected whose name matches the supplied wildcard pattern. (It is not required that all selected files match the pattern; only one.) You can also combine this with dirs for a button that works if a folder is selected or if a file of a certain type is selected. If you use type, it must be the last thing on the line, since everything after the = will be considered part of the pattern (allowing the pattern to include things which would otherwise be confused with other keywords and parameters).
@disablenosel:type=*.jpgdisable button when no files ending with ".jpg" are selected
@disablenosel:type=olddisable button when no files beginning with "old" are selected
@disablenosel:dirs,type=*.pngdisable unless any folders, or any files ending with ".png", are selected
You can also use a ! character to negate the test. It must be the first thing after the :. For example,
@disablenosel:!type=*.jpgdisable button if files ending with ".jpg" are selected
@enableif
The button will be enabled if the tested command is true. This is similar to the conditional testing offered by the @if modifier described below.
@enableif:Set DUAL=togglebutton will be enabled if the Lister is in dual-display mode
@enableif:!Set DUAL=togglebutton will be enabled if the Lister is NOT in dual-display mode
@enableifpath
@enableifpathr
The button will be enabled if the current source path matches the specified pattern. You can provide either an absolute path to test against, or a wildcard pattern (use @enableifpath for standard wildcards, and @enableifpathr for regular expressions). You can also use the keyword shell to test for a hosted shell namespace extension (virtual folder).
@enableifpathr:^C:\\enable command if source path is on the C: drive
@enableifpath:!*\Work\*enable unless source path is underneath a folder called Work
@enableifpath:!/desktopenable unless in the Desktop folder
@enableifpath:!%SystemRoot%\System32enable unless in C:\Windows\System32 (on a typical system)
@enableifpath:{apppath|dopus.exe}enable if in the folder where Opus is installed
@enableifpath:shellenable if in a hosted virtual folder
@eval
@evalalways
Runs Evaluator code as part of a dynamic test, and optionally as part of the command itself. Typically you would use this to set Evaluator variables which can be used on later lines in the command.
  • Code after @eval: is only run when dynamically updating the button's label, visibility and enabled/disabled state. It's not run when the button is clicked.
  • Code after @evalalways: also runs when the button is clicked. This lets you set up variables which are used both when executing commands and, e.g. also when updating their labels.
In this example, the type value is initialised once in the top line, and then referred to multiple times in the subsequent lines.
@eval:type = PathType(source); fIsFileSystem = (type == "shell" || type == "filesys")
@showif:=fIsFileSystem
@label:fIsFileSystem ? ("Open " + FilePart(DisplayName(source)) + " in Explorer") : ("Disabled (" + type + ")")
@externalonly
Ignores any Opus internal commands specified in the function, and treats all commands as external. This lets you configure an MS-DOS batch function using commands like copy which would normally be overridden by the internal command set.
@externalonlyexternal commands only
@filesfromdroponly
Accepts files and folders only via drag-and-drop. A button with this modifier will ignore any selected files or folders in the Lister - only files dropped onto the button will be used by a command within it.
@filesfromdroponlyaccept files only via drag-and-drop
@filesonly
The function will operate only on selected files, ignoring any folders.
@filesonlyoperate only on files
@firstfileonly
The function will operate on only the first selected file, irrespective of how many items are selected or dropped onto the button.
@firstfileonlyoperate on only the first selected file
@functype
This directive is only used within an embedded function. It lets you specify the type of the embedded function (if not specified, the embedded function is assumed to be a standard function - Opus or external command). For example, the following command would open a new Lister with an embedded script function that runs in the context of the new Lister:
Go NEW
@functype:script
@script:vbscript
' script function here
@functype:scriptthe embedded function is a script
@functype:msdosthe embedded function is an MS-DOS batch function
@hideblock
The @hideblock modifier lets you use the various other modifiers to hide or show multiple buttons at once, without having to repeat the tests in each button.
Use @hideblock:begin on a button to begin the block, along with whichever other modifiers are appropriate. The buttons within the block will be hidden or shown depending on the state of the first button. For example,
@hideif:!Set VIEW=Thumbnails
@hideblock:begin
This button begins a hide/show block based on the current view mode. If the current view is in thumbnails mode, the buttons will be visible - otherwise they'll be hidden.
Use @hideblock:end on another button to end the block. All buttons between the beginning and end will be hidden or shown as one. Note that the beginning and ending buttons are never shown outside of Customize mode.
@hideblock:beginbegin a hide block
@hideblock:endend a hide block
@hideif
The button will be hidden if the tested command is true. This is similar to the conditional testing offered by the @if modifier described below.
@hideif:Set DUAL=togglebutton will be hidden if the Lister is in dual-display mode
@hideif:!Set DUAL=togglebutton will be hidden if the Lister is NOT in dual-display mode
@hideifpath
@hideifpathr
The button will be hidden if the current source path matches the specified pattern. You can provide either an absolute path to test against, or a wildcard pattern (use @hideifpath for standard wildcards, and @hideifpathr for regular expressions).
@hideifpathr:^C:\\hide command if source path is on the C: drive
@hideifpath:!*\Work\*hide unless source path is underneath a folder called Work
@hideifpath:!/desktophide unless in the Desktop folder
@hideifpath:!%SystemRoot%\System32hide unless in C:\Windows\System32 (on a typical system)
@hideifpath:{apppath|dopus.exe}hide if in the folder where Opus is installed
@hidenosel
The button will be hidden when no files or folders are selected, or optionally when no files of a certain type are selected. This is similar to @disablenosel.
@hidenoselhide button when nothing is selected
@hidenosel:fileshide button when no files are selected
@hidenosel:dirshide button when no folders are selected
For lister toolbars, you can use the minfiles, maxfiles and numfiles keywords to specify a minimum, maximum, or exact number of files which must be selected for the button to be visible. Similarly, mindirs, maxdirs and numdirs can limit the number of selected folders.
@hidenosel:numfiles=2hide button unless exactly 2 files are selected
@hidenosel:maxfiles=5hide button unless 5 files or fewer are selected
@hidenosel:mindirs=3,maxdirs=5hide button unless 3, 4 or 5 folders are selected
Using the type keyword you can configure a button to be hidden unless at least one file is selected whose name matches the supplied wildcard pattern. (It is not required that all selected files to match the pattern; only one.) You can also combine this with dirs for a button that is visible if a folder is selected or if a file of a certain type is selected. If you use type, it must be the last thing on the line, since everything after the = will be considered part of the pattern (allowing the pattern to include things which would otherwise be confused with other keywords and parameters).
@hidenosel:type=*.jpghide button when no files ending with ".jpg" are selected
@hidenosel:type=oldhide button when no files beginning with "old" are selected
@hidenosel:dirs,type=*.pnghide unless any folders, or any files ending with ".png", are selected
@hidenosel:!type=*.jpghide button if files ending with ".jpg" are selected
@icon
@icon!
@iconp
The @icon directive lets you create buttons that dynamically change their icon based on the test of a command clause, typically via the Set command (similar to @if and @ifset). The default View Mode Cycle button uses this to change its icon to reflect the current view mode.
Set VIEW=Cycle
@icon:largeicons,Set VIEW=LargeIcons
@icon:smallicons,Set VIEW=SmallIcons
@icon:listmode,Set VIEW=List
@icon:powermode,Set VIEW=Power
@icon:thumbnails,Set VIEW=Thumbnails
@icon:tile,Set VIEW=Tiles
@icon:detailsmode,Set VIEW=Details
Each @icon directive in the button specifies the icon to use, and the command directive to test for. For example, if Set VIEW=LargeIcons tests as true, the icon called largeicons will be displayed on the button. If none of the @icon tests match then the icon set in the button itself will be used as the default image.
In the special case of a three-button button, @iconp: and @icon!: directives can also be used in any of the child buttons to change the icon of the parent. @iconp: used in one of the child buttons will set the icon of the parent (but do nothing to the child button). icon!: used in one of the child buttons will set the icon of the parent as well as of that child button.
If you are testing based on the Set command, the command name is technically optional and can be ommitted. For example, VIEW=LargeIcons on its own is the same as Set VIEW=LargeIcons. This ability is there to avoid breaking old buttons and, with new buttons, we recommend you include the command name in all cases to avoid problems in the future.
In the command editor, you can Ctrl+click the @icon: string to select the icon directly.
@icon can use the RECYCLEBINEMPTY argument to test if the recycle bin is empty or not. For example,
@icon:c:\icons\empty.png,RECYCLEBINEMPTY
Toolbar buttons that use @icon with RECYCLEBINEMPTY will refresh themselves automatically when the recycle bin state changes (this lets you have a button whose icon reflects the state of the recycle bin).
Note that in a three-button (multifunction) button, you can make the top-level button take its icon from @icon directives in its child buttons by turning on the Dynamic icon/label from child buttons option on the parent.
@if
@ifset
Allows simple conditional behaviour based on tests for various commands.
@if is a general test which works with any command, and @ifset is a specific test which only works with the Set command conditions. For example, @ifset:DUAL=on is equivalent to @if:Set DUAL=on.
The test @if actually performs is to evaluate whether a toolbar button with the specified command would appear highlighted or not. For example, if the Lister is in dual-display mode, a button with Set DUAL=toggle as the command would appear highlighted. Therefore, the @if:Set DUAL=toggle modifier would evaluate to true.
You can also evaluate whether a toolbar button would be enabled or not, using @if:enabled. For example, Navigation Lock is only enabled when a Lister is in dual-display mode. Therefore, the modifier @if:enabled Set NAVLOCK=Toggle would evaluate to true when the Lister was in dual-display mode.
You can also test if a variable has been set by the @set directive. Additionally, a button on the File Display toolbar can test if it's tied to the left or right file display.
For example, you could configure a button to read a folder into the right file display in a dual-display Lister, or into the current file display otherwise.
@if:Set DUAL=on           	// if DUAL mode is on
Set FOCUS=right             // give focus to the right file display
Go /mypictures OPENINRIGHT  // read directory into that file display
@if:else                    // otherwise
Go /mypictures              // read directory into current file display
@if:common                  // common commands (always executed)
Set VIEW=thumbnails         // set view to thumbnails mode
As another example, @ifset can use the RECYCLEBINEMPTY argument to test if the recycle bin is empty or not:
@ifset:RECYCLEBINEMPTY
@confirm The recycle bin is empty!
@ifset:else
Delete EMPTYRECYCLE
Conditional testing can also be used on buttons in the standalone viewer. The following function will toggle the display between 100% zoom and Grow To Page modes, by using @if to test the current zoom mode:
@if:Show VIEWERCMD=zoom,reset
Show VIEWERCMD=zoom,grow
@if:else
The possible forms of this modifier are:
@if:<command line>test if a specific command condition is true
@ifset:<Set command argument>test for a specific Set command condition
@if:enabled <command>test if a command button would be enabled (rather than highlighted)
@if:$footest if a variable called "foo" has been set
@if:$glob:bartest if a global variable called "bar" has been set
@if:SIDE=lefttest if the toolbar is tied to the left file display
@if:SIDE=righttest if the toolbar is tied to the right file display
@if:&&ARG&&=valuetest if a User-defined command argument matches a given value
@if:&&ARG&&!=valuetest if a User-defined command argument doesn't match a given value
@if:elsean "else" clause that is executed if nothing else matches
@if:commoncommon instructions that are always executed
You can negate the condition by prefixing it with a ! character. For example, all four of these are equivalent:
@if:!Set DUAL=on
@if:Set DUAL=off
@ifset:!DUAL=on
@ifset:DUAL=off
@ifexists
Allows simple conditional behaviour based on whether the specified drive or path exists. The final component of a path can contain standard wildcards if the wild: prefix is used.
@ifexists:<drive or path>test if drive or path exists
@ifexists:wild:<drive or path>test if drive or path exists. Allows wildcards in the final path component
@ifexists:!<drive or path>test if drive or path does not exist
@ifexists:elsean "else" clause that is executed if the path doesn't exist
@ifexists:commoncommon instructions that are always executed
@ifsel
Lets a function do different things depending on file or folder selection. The available tests are the same as for the @disablenosel modifier (documented above).
For example,
@ifsel:numfiles=2
<run program that accepts exactly two files>
@ifsel:else
<show an error message>
@ifpath
@ifpathr
Allows simple conditional behaviour based on the current source path. You can provide either an absolute path to test against, or a wildcard pattern (use @ifpath for standard wildcards, and @ifpathr for regular expressions).
For example, you could use this to open different programs when double-clicking on an image file, depending on where the file is stored. If the following command was added to the Left double-click event for the Images file type group, pictures located on the network will be opened in the Opus viewer when they are double-clicked, whereas files located on a local drive would open in Photoshop.
@ifpath:\\*                      // if path begins with \\
Show                             // invoke the Opus viewer
@ifpath:else                     // otherwise...
Photoshop.exe {f}                // open in Photoshop (the full path would generally need
                                 // to be specified - this is just an example)
@ifpath:<path or wildcard>test for a path (using standard pattern matching)
@ifpathr:<regular expression>test for a path (using regular expressions)
@ifpath:elsean "else" clause that is executed if nothing else matches
@ifpath:commoncommon instructions that are always executed
Examples:
@ifpath:C:\Program FilesTests you are in C:\Program Files
@ifpath:!C:\Program FilesTests you are anywhere but C:\Program Files
@ifpath:C:\Program Files\*Tests you're in a folder below C:\Program Files (does not include Program Files itself)
@ifpath:!C:\Program Files\*Tests you are not in a folder below C:\Program Files
@ifrunning
Allows simple conditional behaviour based on whether a specified process is currently running. You can use wildcards or (by prefixing the pattern with regex:) regular expressions.
@ifrunning:notepad.exetest if Notepad is running
@ifrunning:!note*test if a process starting with "note" is not running
@ifrunning:elsean "else" clause that is executed if the process doesn't exist
@ifrunning:commoncommon instructions that are always executed
@keydown
Allows simple conditional behaviour based on whether various qualifier keys are held down when the function is run.
The qualifiers to test for are specified using one or more keywords (shift, ctrl and alt) which represent the Shift, Ctrl and Alt keys. For example, you could configure a button to select all files, then copy, move or create shortcuts to them, depending on which keys were held down.
Select ALL              // select all items (always executed)
@keydown:none           // if no qualifiers are down
Copy                    // copy files to destination
@keydown:shift          // else if shift key is down
Copy MOVE               // move files to destination
@keydown:ctrlshift      // else if both control and shift keys are down
Copy MAKELINK           // make shortcuts in destination
@keydown:<qualifiers>test for a qualifier key or combination of keys
@keydown:!<qualifiers>test for a qualifier key or combination of keys NOT being down
@keydown:any tests if any qualifier keys are held down
@keydown:noneinstructions that are executed if no qualifiers are held down
@keydown:commoncommon instructions that are always executed
@label
TOBEDONE
If something modifies variables, or other factors that affect dynamic labels, it should notify Opus so labels and toolbar layouts can be updated. Commands should use @toggle:update (see below) and scripts can use Command.UpdateToggle to do this.
@leavedoswindowopen
The console window opened for an MS-DOS batch function will remain open when the function has completed. Without this modifier the window will close when the function finishes, which may make it hard to read the output of any command-line programs.
Leaving the DOS window opens relies on passing a particular argument (/K) to the system command interpreter, cmd.exe. If you have modified the default command processor on your system by setting the %ComSpec% environment variable, Opus will not pass /K as there is no way for it to know if this argument would be understood by the new command processor. Instead, you can set the %ComSpecLeaveOpenArg% environment variable, and this will be used instead of %ComSpec% whenever @leavedoswindowopen is used.
@leavedoswindowopenleave DOS prompt open when function finishes
@logusage
Instructs Windows to log usage of programs or documents opened by this function. Typically this means any files used will be added to the recent documents list, and any programs that are launched are added to the recent applications list.
@logusagelog usage of files and applications
@nocall
An MS-DOS batch function function that invokes an external .bat file will run it directly, rather than using call semantics. This means that control will not return to the parent function once the external .bat file has finished. The default behaviour is to use the DOS call instruction which returns control to the parent function at the end.
@nocall:<batch file>invoke external batch file, do not return control to this function
@nodeselect
Files and folders will remain selected at the end of the function. This lets you override the Deselect files used in functions option on the File Operations / Options page in Preferences, on a per-function basis.
@nodeselectdo not deselect items used by this function
@noexpandenv
Prevent the expansion of any environment variables in the function. Normally environment variables like %USERPROFILE% are expanded during the function parsing phase - this modifier causes variable names to be left intact.
@noexpandenvdo not expand environment variables
@nofilenamequoting
Disables the automatic quoting that Opus performs when external codes like {filepath} are used to pass the name of a file that contains spaces. By default Opus will wrap names with embedded spaces in quotes, but occasionally you may want to disable this - some external programs may not need or understand quotes on their command line, and you may also want to provide explicit quotes in a function in case the automatic quoting gets confused by complicated command structures.
@nofilenamequotingdo not automatically quote file names and paths
@nolocalizefiles
Prevents Opus from automatically downloading or extracting non-filesystem files when passing their paths to external programs. For example, you may want to use {filepath} to pass the ftp:// path of a file on a remote FTP server to an external program. By default Opus will download the file to a temporary file, and pass the name of the temporary file to the program - with this modifier, Opus will instead pass the original file path.
@nolocalizefiles
@noprogress
Disables the automatic display of a progress indicator for this function. You should use this with care as without a progress indicator there is no way to abort the command or monitor its progress. Normally only script functions should use this when they want to provide and control their own progress indicator.
@noprogressdo not display an automatic progress dialog for this function
@norunbatch
When an MS-DOS batch function combines internal and external commands, the default behaviour is for Opus to split the function at every internal command, and execute all the external commands that came before it. For example, imagine the following (rather pointless) function:
echo one
Help ABOUT
echo two
@leavedoswindowopen
The default behaviour of this function would be to open a DOS window and print the string "one", then display the Opus About dialog, and then open another DOS window and print the string "two". If, however, the function were changed as follows:
@norunbatch
echo one
Help ABOUT
echo two
@leavedoswindowopen
The new behaviour would be to first display the About dialog, and then open a single DOS window and print both the strings "one" and "two". The @norunbatch modifier causes all Opus internal commands to be executed first, followed by all external commands.
@norunbatchdo not split batch functions because of internal commands
@output
Outputs all text on the rest of the line to the Script Log. Useful for debugging. The output can also be viewed in the Command Editor when its *Run With Logging* mode is on.
@output <message>sends <message> to the Script Log
@perfile
Allows a block of commands to be run once per file. Normally, functions containing multiple command lines run each command separately for all selected files.
For example,
echo 1 {file}
echo 2 {file}
With two files, "Apple.txt" and "Banana.txt" selected, this would output:
1 Apple.txt
1 Banana.txt
2 Apple.txt
2 Banana.txt
Using @perfile around these commands like so:
@perfile:begin
echo 1 {file}
echo 2 {file}
@perfile:end
This would output:
1 Apple.txt
2 Apple.txt
1 Banana.txt
2 Banana.txt
Use @perfile:begin to mark the beginning of the per-file block and @perfile:end to mark the end.
@resolvelinks
Shortcuts or links passed to commands in this function will be resolved to their targets. Without this modifier, a selected .lnk file would be passed as-is.
@resolvelinksresolve shortcut targets when passing filenames to commands
@runbatch
Force the execution of an MS-DOS batch function at a certain point. The default behaviour is for such functions to be executed at the very end of the function - using this modifier you can force a break in the function at any line. For example:
echo one
@runbatch
echo two
@leavedoswindowopen
This will cause two separate DOS windows to open, one displaying the text "one" and the other displaying "two". Without the @runbatch directive, the two commands would have been executed in the one window.
@runbatchforce a DOS batch function to execute at a certain point
@runmode
Modifies the "run" state of external programs launched by the function - that is, how its main window should appear. This is equivalent to the Run drop-down on the simple command editor. Not all programs will support this setting, so you will need to use trial and error to some extent. You should only set the mode to hide if you are sure of what you are doing - it is most useful for hiding the otherwise brief flash of a DOS window when running a DOS program.
@runmode:minminimize the program's main window
@runmode:maxmaximize the program's main window
@runmode:hidehide the program's main window
@runonce
Forces the command following the modifier to only be run once per function, instead of once per file.
@runonce:<command>the specified command will only be run once
@script
Specifies the scripting language used for a script. This is mainly used for embedded rename scripts, because otherwise the script language is selected via a drop-down at the top of the script editor. The @script modifier must be followed by a keyword that specifies the scripting language (or in the case of script add-ins, the file extension of the add-in itself specifies the language).
For example,
Rename PATTERN * TO *
@script:vbscript
Function ....
@script:<language>specifies scripting language for Rename command
@set
Sets the value of a named variable that can be used by the remainder of the commands in the function. You can pass the value of a variable to internal and external commands using the {$} control code. Variables are most useful in the situation where the value is defined by a {dlgstring} code. For example,
@set dir={dlgstring|Enter new folder name to copy files to}
CreateFolder ".\{$dir}"
Copy TO ".\{$dir}"
Normally, variables do not persist from one invocation of the function to another, and you can not refer to variables set in one function from another. However this can be accomplished by prefixing the variable name with a special scope marker that determines which scope the variable will live in.
src:<name>variable will be scoped to the source folder tab
dst:<name>variable will be scoped to the destination folder tab
left:<name>variable will be scoped to the left folder tab
right:<name>variable will be scoped to the right folder tab
tab:<name>variable will be scoped to the active folder tab (see below)
lst:<name>variable will be scoped to the Lister (the whole window)
glob:<name>variable will be scoped globally
The src: and tab: scopes usually point to the same folder tab within commands. (The tab: scope was introduced so that status bar codes which use variables can refer to the side that the status bar is on, without worrying if it is the source, destination, left or right. It is supported in commands for consistency.)
You can also mark variables to be saved on disk - their values will be remembered from one Opus session to the next. To accomplish this, simply add an exclamation mark (!) to the scope marker. For example,
glob!:<name>refers to a variable with global scope that will be saved on disk.
@set <name>=<value>sets the named variable to the specified value
@set <name>deletes the named variable
If you have buttons or status bar codes which react to variable changes, you may need to run the special @toggle:update command to make them update their appearances after making changes to variables. See the @toggle documentation, below.
@sendkey
Sends the specified keystroke to the system. The key will be routed to whichever window currently has focus. For example, @sendkey:win+v sends the Win+V key to the system, which opens the Windows clipboard viewer.
Supported qualifier keys are shift, ctrl, alt and win.
As well as letters and numbers, the following named keys are also supported: backspace, capslock, delete , down, end, enter, escape, home, insert, left, numlock, pagedown, pageup, pause, printscr, right, scrlock, space, tab, up.
@showif
The button will be shown if the tested command is true. This is similar to the conditional testing offered by the @if modifier.
@showif:Set DUAL=togglebutton will be shown if the Lister is in dual-display mode
@showif:!Set DUAL=togglebutton will be shown if the Lister is NOT in dual-display mode
@showifpath
@showifpathr
The button will be shown if the current source path matches the specified pattern. You can provide either an absolute path to test against, or a wildcard pattern (use @showifpath for standard wildcards, and @showifpathr for regular expressions).
@showifpathr:^C:\\show command if source path is on the C: drive
@showifpath:!*\Work\*show unless source path is underneath a folder called Work
@showifpath:!/desktopshow unless in the Desktop folder
@showifpath:!%SystemRoot%\System32show unless in C:\Windows\System32 (on a typical system)
@showifpath:{apppath|dopus.exe}show if in the folder where Opus is installed
@sync
The command following this modifier will be run synchronously - Opus will wait for it to exit before running the next command in the function (or before running this command again for the next selected file).
@sync:notepad.exe {f}runs Notepad synchronously
@toggle
For buttons that indicate or change state (e.g. Set VIEW=details), this modifier lets you change when the button appears highlighted.
Depending on where the button is displayed, the highlight may appear as a checkmark (e.g. in a text-only menu), or as the icon or label background being drawn in a different color or style (similar to when the button is pushed).
Taking the Set VIEW=details command as an example, ordinarily the button would appear highlighted when the file display was in details mode, and not highlighted when it was in any other mode. The @toggle modifier can change this:
@toggle:invertinverts the usual highlight state of the toolbar button
@toggle:disableprevents the button from ever appearing highlighted
The @toggle modifier can also control when a button appears highlighted by testing a command, similar to the way @if and @ifset test commands to decide what to run. You can use this to highlight a button based on a command which is different to, or in addition to, the commands which the button actually runs.
For example, this button with no @toggle line will switch you to Details mode when clicked, and will appear highlighted when you are in Details mode as well:
Set VIEW=Details
When @toggle is not given, the highlighting (if any) is based on the first command in the button.
Using @toggle you can do things like run one Set command while testing for another. As a simple, somewhat contrived example, the button below switches to Details mode when clicked but appears highlighted when in Power mode:
Set VIEW=Details
@toggle:if Set VIEW=Power
You can make the @toggle test in addition to the first command, rather than instead of it, by putting an "&" character after the "if":
Set VIEW=Details
Set COLUMNSADD=thumbnail(0,96)
@toggle:if&Set COLUMNSTOGGLE=thumbnail
Without the @toggle line, the button above would be highlighted when the view mode was Details (due to the command) and the highlight would not be affected by the Thumbnail column (highlighting does not consider the second command). With the @toggle line added, the button will only be highlighted if the view mode is set to Details and the Thumbnail column is present.
You can omit the "Set" command name from the @toggle line; it will assume you mean the Set command if no name is specified. However, this allowance is to avoid breaking old buttons and we recommend you always specify the command when making new ones.
You can test for multiple commands at once by separating them with semi-colons. For example, you could leave out the ampersand and still test for both Details mode and the Thumbnail column using the following directive (and this will work regardless of any other commands in the button, or even as the only line in the button):
@toggle:if Set VIEW=Details;Set COLUMNSTOGGLE=thumbnail
You can also negate the result of a test with the exclamation mark in front of the Set clause. For example, to make the button appear checked in any mode other than Details:
@toggle:if !Set VIEW=Details
The @toggle directive can also test for the existence of a variable (one set via the @set directive). For this to work, the directive must be the very first line of the button, and the variable you are testing must have tab, Lister or global scope. You can use this to create your own custom toggle buttons that keep track of their state using scoped variables. For example:
@toggle:if $glob:TestVar
@if:$glob:TestVar
@set glob:TestVar
@if:else
@set glob:TestVar=on
This button tests for the existence of a global variable called TestVar. If the variable exists, the button will appear highlighted. Clicking the button evaluates the @ifset: directives and will reverse the state of the variable: if the variable is set, it will be deleted; otherwise, it will be set. The end result is a button that performs no function except to toggle a variable and its visible state each time it is clicked. (This can be useful if the variable controls other things, such as the behaviors of other commands or scripts, or the visibility of status bar elements.)
A button that begins with @toggle:if in this way will automatically update its appearance (to reflect a change in the state of the variable) whenever @set is used within it. If you use @set in a separate button or hotkey to change the variable, you need to force an update of the toggle button's appearance using the special command @toggle:update.
For example, if you have one button which highlights based on a variable but does not change that variable:
And if you have another button which changes that variable but does not highlight based on it, then you will need to add the @toggle:update line to ensure the first button's highlight is updated when you click the second button:
@if:$glob:TestVar
@set glob:TestVar
@if:else
@if:common
@toggle:update
The @toggle:update command will also force all status bars to refresh, in case they are using variables to display or hide information.
You can also use @toggle:update to ensure buttons with dynamic labels (via @label, above) are updated after changing variables or other details the label depends on. This also ensures toolbar layouts are adjusted if the label widths change.
@useactivelister
The function will operate on the active Lister rather than the current source Lister. Normally these will be the same thing, but this could be useful for a hotkey that you want to have operate on whatever Lister window is currently active, without having to make sure that Lister is set to source first.
@useactivelisteruse active Lister instead of source lister
@useimagedata
When running the Image CONVERT command from the Standalone Viewer, the command normally reads the image in from disk. Specifying @useimagedata in the command will instead feed the currently displayed bitmap data directly from memory into the command, ignoring the file on disk.
This allows you to crop, rotate, or otherwise modify the image in the viewer and then save it out in a new file format. The Image CONVERT command also has a NOUSEIMAGEDATA argument to override this, for example if you want to run multiple conversions where some use the in-memory bitmap and some act on the file on disk.
@useimagedatamake Image CONVERT work on the displayed bitmap in memory
