Toggle theme
Directory Opus Manual
User Tools
Toggle theme
Log In
Site Tools
Search
You are here:
Introduction
Preferences
Preferences Categories
Colors And Fonts
Sidebar
Copyrights
Licenses
Acknowledgements
Introduction
New In Directory Opus 13
Using Directory Opus
Basic Concepts
File Operations
FTP
Additional Functionality
Configuration
Preferences
Backing up and Restoring Preferences
Colors And Fonts
Dark Mode
Themes
Color Blending
Directory Opus Colors
Windows Colors
Images
Fonts
File Displays
File Display Columns
File Display Modes
File Operations
Filtering And Sorting
Folders
Folder Tabs
Folder Tree
Frequently Used Paths
Internet
Labels
Launching Opus
Layouts and Styles
Location Bar
Miscellaneous
Toolbars
User Interface
Viewer
Zip and Other Archives
Customize
File Types
Programming
Scripting
Evaluator
Reference Section
Wildcards and RegEx
Commands
Status Bar Codes
Metadata Keywords
Script Objects
Script Events
Evaluator Functions
DOpusRT
Textual Filters
Icon Sets
Rename Macro Language
preferences:preferences_categories:colors_and_fonts
Colors And Fonts
This category contains options relating to the appearance of Directory Opus.
Dark Mode
: Switch between the light and dark modes
Themes
: Save your color and font settings as a "theme" that you can share with others
Color Blending
: Options relating to the way different colors are combined (blended)
: Edit the colors used by the user interface except for controls
Windows Colors
: Edit the colors used Windows controls in Directory Opus
Images
: Set background images for various parts of the interface.
Fonts
: Edit the fonts used by the user interface
