reference:command_reference:internal_commands:help
The Help internal command can be used to:
  • Display the program help file
  • Display information about the program (the About dialog)
  • Check for program updates
  • Access the licence manager to install your program certificate
  • Send a quick email
Command Arguments:
Possible values Description
(no argument) -
- Displays the program help file.
Example: Help
ABOUT /S
(no value) Displays the About dialog, showing information about the current version of the program, copyright and contact details for technical support.
Example: Help ABOUT
CHECKUPDATE /O
(no value) Checks online for program updates.
Example: Help CHECKUPDATE
quiet Perform a silent check for updates - a dialog will only be displayed if an update is found.
Example: Help CHECKUPDATE=quiet
CLOUDDIAGNOSTIC /S
(no value) Displays diagnostic information about the various cloud storage providers on your system, in the diagnostic log.
Example: Help CLOUDDIAGNOSTIC
CRASHLOGS /S
(no value) Displays the Crash Logs dialog, which shows any crash logs that have been automatically generated and lets you submit them to GPSoftware for analysis.
LANG /K
<language name> Displays a help file in the specified language, if one exists.
Example: Help LANG=deutsch
LICENCEMANAGER /S
(no value) Displays the licence manager, where you can view and manage your current program licence, or apply for a free evaluation licence.
Example: Help LICENCEMANAGER
NEWEMAIL /S
(no value) Sends a quick email message. You must have configured Opus to send email via SMTP (on the Miscellaneous / Email page in Preferences) for this function to work.
Example: Help NEWEMAIL
REF /K
commands
dopusrt
metadata
statusbar
wildcards
scripting
cmd_name
Provides a shortcut to displays certain reference sections of the help file. For example, you could define a hotkey to take you directly to the Wildcards reference section.
Example: Help REF=wildcards
Example: Help REF=cmd_CreateFolder
RELEASENOTES /S
(no value) Displays the release notes for the current version.
Example: Help RELEASENOTES
TASKMANAGER /S
(no value) Displays the Task Manager, a window which displays a list of various types of running Opus tasks.
Example: Help TASKMANAGER
THEMETESTER /S
(no value) Opens a UI which can be useful for testing how various standard Windows controls look with colors from custom themes.
Example: Help THEMETESTER
