reference:evaluator:keydown
KeyDown(
     string:key,
     [string:key...]
bool
Arguments
key
Qualifier key to test for.
key...
Optional. Second qualifier key...
Return value
True if specified key is down.
Description
Returns True if the specified qualifier key or keys are held down. If multiple keys are provided, all must be held down to return true.
Valid keywords are none, shift, ctrl and alt.
Example:
if (KeyDown("shift", "ctrl"")) { ... } // are both shift and ctrl are down?
