reference:evaluator:max
Max(
     var:value1,
     var:value2,
     [var:value3...]
→ var
Arguments
value1
Value to compare.
value2
Value to compare.
value3...
Optional. Value to compare...
Return value
Largest of the input values.
Description
Returns the largest of the provided input values. You can provide as many values as you like..
The values should all be the same type as each other (e.g. all numbers, all dates, etc.)
Example:
Output( Max(2, -5, 7, 1) );
--> 7
See also: Min
