reference:evaluator:isselected
IsSelected(
     string:pattern,
     [string:pattern...]
→ bool or int
Arguments
pattern
Filename wildcard pattern. Prefix with dirs: to only match directories or files: to only match files.
pattern...
Optional. Additional filename patterns...
Return value
Result of the test for selected items.
Description
With a single pattern specified, returns True if items matching that pattern are currently selected, otherwise returns False.
With multiple patterns specified, returns 0 is no patterns match selected items, otherwise returns the index of the first match.
Example:
if (IsSelected("*.jpg")) { ... } // one or more jpgs are selected
See also: FileCount
