reference:plugins:viewer_plugins:supporting_usb_export
To support the USB export functionality in Directory Opus, a plugin needs to mark itself as "USB-safe". This basically means that the plugin does not save configuration data in the registry or make any other changes to the system it runs on. All configuration data should be saved in XML format using the functionality provided in the Plugin Support API (documented separately.)
To mark your plugin as USB-safe, you must export the DVP_USBSafe function.
  • DVP_USBSafe - marks the plugin as safe for USB export
