reference:plugins:viewer_plugins:properties_configuration_and_about_functions
There are several additional functions that may optionally be implemented by a viewer plugin.
The Properties functions (DVP_ShowProperties for disk-based files and DVP_ShowPropertiesStream for virtual files) are called by Directory Opus if you have specified the DVPFIF_CanShowProperties flag for a file and the user selects the Properties function from the viewer context menu. Note that these functions are only used if your plugin supports the bitmap method of viewing files; if you have created your own viewer window, your window will instead receive a DVPLUGINMSG_PROPERTIES message.
If you do not implement your own Properties interface then Directory Opus will provide its own standard Properties dialog. You can disable the Properties function altogether by specifying the DVPFIF_NoProperties plugin flag.
