reference:plugins:viewer_plugins:exported_functions
A viewer plugin DLL must export at least three functions to be useful, and may export as many as eleven. Only one function, DVP_Identify, is mandatory.
The exported functions are listed here; see the following pages for full descriptions of them.
DVP_Initinitialize the plugin
DVP_InitExalternative initialization function
DVP_Uninituninitialize the plugin
DVP_USBSafemarks the plugin as safe for USB export
DVP_Identifyidentifies the plugin
DVP_IdentifyFilecan the plugin identify/view a disk file?
DVP_IdentifyFileStreamidentify/view a data stream?
DVP_IdentifyFileBytesidentify/view a file based on the file header?
DVP_LoadBitmapload a bitmap from a disk file
DVP_LoadBitmapStreamload a bitmap from a data stream
DVP_LoadTextload text from a file which Opus will display
DVP_CreateViewercreate custom file viewer window
DVP_ShowPropertiesdisplay custom properties dialog for a disk file
DVP_ShowPropertiesStreamdisplay custom properties dialog for a data stream
DVP_GetFileInfoFileget information about a file
DVP_GetFileInfoFileStreamget information about a data stream
DVP_Configuredisplay configuration dialog for the plugin
DVP_Aboutdisplay About dialog for the plugin
Most functions are supported in both multi-byte and Unicode versions, using the A and W nomenclature used in the Win32 API. The viewer plugin header file defines a version of the function without the A or W suffix as the appropriate real function name based on whether or not the UNICODE symbol has been defined.
