Toggle theme
Directory Opus Manual
User Tools
Toggle theme
Log In
Site Tools
Search
You are here:
Introduction
Reference
Plugins
Viewer Plugins
DVP_Init
Sidebar
Copyrights
Licenses
Acknowledgements
Introduction
New In Directory Opus 13
Using Directory Opus
Basic Concepts
File Operations
FTP
Additional Functionality
Configuration
Preferences
Customize
File Types
Programming
Scripting
Evaluator
Plugins
Reference Section
Wildcards and RegEx
Commands
Status Bar Codes
Metadata Keywords
Script Objects
Script Events
Evaluator Functions
DOpusRT
Textual Filters
Icon Sets
Rename Macro Language
Plugins
Viewer Plugins
DVP_About
DVP_Configure
DVP_CreateViewer
DVP_GetFileInfoFileStream
DVP_GetFileInfoFile
DVP_IdentifyFileBytes
DVP_IdentifyFileStream
DVP_IdentifyFile
DVP_Identify
DVP_InitEx
DVP_Init
DVP_LoadBitmapStream
DVP_LoadBitmap
DVP_LoadText
DVP_ShowPropertiesStream
DVP_ShowProperties
DVP_Uninit
DVP_USBSafe
VFS Plugins
Plugin Support API
reference:plugins:viewer_plugins:dvp_init
DVP_Init
BOOL
Return value
A return code of
TRUE
indicates that plugin initialization should continue; a return of
FALSE
means that Directory Opus will not load the plugin.
Description
The
DVP_Init
function is called to initialize the plugin.
