reference:plugins:viewer_plugins:dvp_identifyfilestream
DVP_IdentifyFileStream(
     HWND:hWnd,
     LPSTREAM:lpStream,
     LPTSTR:lpszName,
     LPVIEWERPLUGINFILEINFO:lpVPFileInfo,
     DWORD:dwStreamFlags
→ BOOL
Arguments
hWnd
This parameter specifies the parent window handle that should be used to display any error messages if appropriate.
lpStream
This points to an IStream COM object that you must read from in order to identify the file contents. The dwStreamFlags parameter provides additional information about this data stream.
lpszName
Supplies the name of the file, including the full path. However, as this is not a real disk file the only use for this is for identifying the file based on the file name extension.
lpVPFileInfo
This parameter points to a VIEWERPLUGINFILEINFO structure that must be filled out if the plugin recognizes and can view the file. See DVP_IdentifyFile for a description of this structure.
dwStreamFlags
This parameter contains flags that describe the data stream specified in the lpStream parameter. You may use this information to decide whether or not your plugin is to handle this file. The flags currently defined are:
DVPSF_SlowIf set, this flag indicates that the data stream is "slow" - that is, access to the file may potentially take a long time. Currently this is only set for FTP sites.
DVPSF_NoRandomSeekIf set, this flag indicates that the data stream does not support random seeking - that it can only be read sequentially from beginning to end. Currently this will be set for both FTP and ZIP files.
Return value
The DVP_IdentifyFileStream function must, if appropriate, fill out the VIEWERPLUGINFILEINFO structure in the same way as the DVP_IdentifyFile function and return either TRUE or FALSE to indicate if the file can be handled.
Description
The DVP_IdentifyFileStream function is called to identify a file from a data stream.
Directory Opus viewer plugins support 'virtual files' or those that are not based on disk media - for example, files residing on remote FTP sites or within ZIP files. To access these files, your plugin must support reading data from an IStream object.
If your plugin specified the DVPFIF_CanHandleStreams flag, and the file to be identified is not a disk-based file, then Directory Opus will call your DVP_IdentifyFileStream function to identify the file.
This function is similar to the DVP_IdentifyFile function except that the filename parameter does not refer to a real disk file that you can open and read from. Instead, you must use the lpStream parameter to read data from the supplied data stream. Please see the Microsoft MSDN library for more information about COM and the IStream interface.
Note that there is no hAbortEvent parameter for this function. This is because the IStream object that Directory Opus supplies supports the abort mechanism internally. If the user aborts your plugin's operation, the data stream will automatically return failure for any attempted read function.
