reference:plugins:viewer_plugins:dvp_getfileinfofile
DVP_GetFileInfoFile(
     HWND:hWnd,
     LPTSTR:lpszName,
     LPVIEWERPLUGINFILEINFO:lpVPFileInfo,
     LPDVPFILEINFOHEADER:lpFIH,
     HANDLE:hAbortEvent
→ BOOL
Arguments
hWnd
This parameter specifies a parent window handle in case you need to display any dialogs.
lpszName
This parameter provides the name of the file, including the full path.
lpVPFileInfo
This parameter points to a VIEWERPLUGINFILEINFO structure that contains the information that you returned in the DVP_IdentifyFile function, including the dwPrivateData field. This allows you to preserve your own data between the calls to DVP_IdentifyFile and DVP_GetFileInfoFile.
lpFIH
This points to a DVPFILEINFOHEADER structure, which is a header to a larger structure (described below).
hAbortEvent
Specifies an event handle that you can use to determine if the user wishes to abort the file info extraction.
Return value
You should return TRUE if file information was successfully retrieved, or FALSE on failure.
Description
The DVP_GetFileInfoFile function is called to get information about a file.
  • LPDVPFILEINFOHEADER lpFIH
    This points to a DVPFILEINFOHEADER structure, which is a header to a larger structure. This structure has the following fields:
    • [in] UINT cbSize
      Specifies the total size of the structure including the header.
    • [in] UINT uiMajorType
      Specifies the type of the structure. This is determined by the value you returned for uiMajorType in the call to VFS_IdentifyFile. Currently two types are supported:
DVPMajorType_SoundDVPFILEINFOMUSIC
DVPMajorType_MovieDVPFILEINFOMOVIE
  • [in] DWORD dwFlags
    Flags field, currently undefined.
As described above, the uiMajorType field in the DVPFILEINFOHEADER structure determines the real type of the information structure passed.
If the uiMajorType value is DVPMajorType_Sound, the structure is a DVPFILEINFOMUSIC structure, which has the following fields:
  • [in] DVPFILEINFOHEADER hdr
    The file info header structure, defined above.
  • [out] LPTSTR lpszAlbum / [in] UINT cchAlbumMax
    Points to a buffer into which you should copy a text string describing the 'Album' property for this file. cchAlbumMax defines the maximum size of this buffer in characters.
  • [out] LPTSTR lpszArtist / [in] UINT cchArtistMax
    A buffer to store the 'Artist' property for this file, and the maximum size of the buffer in characters.
  • [out] LPTSTR lpszTitle / [in] UINT cchTitleMax
    A buffer to store the 'Title' property for this file, and the maximum size of the buffer.
  • [out] LPTSTR lpszGenre / [in] UINT cchGenreMax
    A buffer to store the 'Genre' property for this file, and the maximum size of the buffer.
  • [out] LPTSTR lpszComment / [in] UINT cchCommentMax
    A buffer to store the 'Comment' property and the maximum size of the buffer.
  • [out] LPTSTR lpszFormat / [in] UINT cchFormatMax
    A buffer to store the 'Format' property and the maximum size of the buffer.
  • [out] LPTSTR lpszEncoder / [in] UINT cchEncoderMax
    A buffer to store the 'Encoder' property and the maximum size of the buffer.
  • [out] DWORD dwBitRate, dwSampleRate
    The bit rate (in bits per second) and sample rate (in cycles per second) of the sound file.
  • [out] DWORD dwDuration
    The duration (length) of the sound file in seconds.
  • [out] int iTrackNum
    The track number property of the sound file.
  • [out] int iYear
    The year property of the sound file (normally year recorded.)
  • [out] int iNumChannels
    The number of distinct channels in the sound file.
  • [out] DWORD dwMusicFlags
    Flags field. Currently defined flags are:
    DVPMusicFlag_VBR Set this flag if the sound file has a 'variable bit rate' and therefore reported duration is only an approximation.
    DVPMusicFlag_VBRAccurate Set this flag if the sound file has a 'variable bit rate', but the reported duration is accurate.
    DVPMusicFlag_JointStereo Set this flag if the sound file is 'joint stereo'
  • [out] LPTSTR lpszCodec / [in] UINT cchCodecMax
    A buffer to store the 'Codec' property for the sound file and the maximum size of the buffer in characters.
If the uiMajorType value is DVPMajorType_Movie, the structure is a DVPFILEINFOMOVIE structure, which has the following fields:
  • [out] SIZE szVideoSize
    The dimensions of the video component of the movie, in pixels.
  • [out] int iNumBits
    The pixel depth of the video component of the movie.
  • [out] DWORD dwDuration, dwFrames
    The duration of the movie in seconds and the total number of frames in the movie.
  • [out] double flFrameRate
    The normal frame rate of the movie, in frames per second.
  • [out] DWORD dwDataRate
    The data rate of the video component of the movie, in bits per second.
  • [out] POINT ptAspectRatio
    The aspect ratio of the movie (as a ratio X:Y)
  • [out] DWORD dwAudioBitRate, dwAudioSampleRate
    The bit rate in bytes per second and sample rate in cycles per second of the audio component of the movie.
    The number of distinct audio channels.
  • [out] LPTSTR lpszVideoCodec / [in] UINT cchVideoCodecMax
    A buffer to store the name of the video codec, and the maximum size of the buffer in characters.
  • [out] LPTSTR lpszAudioCodec / [in] UINT cchAudioCodecMax
    A buffer to store the name of the audio codec, and the maximum size of the buffer in characters.
