• Toggle theme
Directory Opus Manual
User Tools
  • Toggle theme
  • Log In
Site Tools
You are here: Introduction » Reference » Plugins » Viewer Plugins » DVP_ConfigurePreTranslateMessageW
Sidebar
  • Copyrights
  • Licenses
  • Acknowledgements
  • Introduction
  • New In Directory Opus 13
Using Directory Opus
  • Basic Concepts
  • File Operations
  • FTP
  • Additional Functionality
Configuration
  • Preferences
  • Customize
  • File Types
Programming
  • Scripting
  • Evaluator
  • Plugins
Reference Section
  • Wildcards and RegEx
  • Commands
  • Status Bar Codes
  • Metadata Keywords
  • Script Objects
  • Script Events
  • Evaluator Functions
  • DOpusRT
  • Textual Filters
  • Icon Sets
  • Rename Macro Language
  • Plugins
    • Viewer Plugins
      • DVP_About
      • DVP_Configure
      • DVP_ConfigureIsDialogMessageW
      • DVP_ConfigurePreTranslateMessageW
      • DVP_CreateViewer
      • DVP_GetFileInfoFileStream
      • DVP_IdentifyFileBytes
      • DVP_IdentifyFileStream
      • DVP_IdentifyFile
      • DVP_Identify
      • DVP_InitEx
      • DVP_Init
      • DVP_LoadBitmapStream
      • DVP_LoadBitmap
      • DVP_LoadText
      • DVP_SetMetaData
      • DVP_ShowPropertiesStream
      • DVP_Uninit
      • DVP_USBSafe
      • DVP_ViewerCacheFree
      • DVP_ViewerCacheLoadW
      • Image Viewer Messages
    • VFS Plugins
    • Plugin Support API
reference:plugins:viewer_plugins:dvp_configurepretranslatemessagew
DVP_ConfigurePreTranslateMessageW(
     HWND:hWndDlg,
     LPMSG:lpMsg
→ BOOL
Arguments
hWndDlg
[in] Handle of the dialog
lpMsg
[in] The message
Description
See also DVP_Configure and DVP_ConfigureIsDialogMessageW.
There is no ANSI version of this function.
