DVP_About(
HWND:hWndParent
→ HWND
The DVP_About function is called to display an About dialog for the plugin.
The remaining exported function is DVP_About, which is called by Directory Opus when the user selects the About function for your plugin and you specified the DVPFIF_CanShowAbout plugin flag. If you do not provide your own About interface then Directory Opus will display a default About dialog using the name, copyright, URL and other information that you provided in the call to DVP_Identify.
