VFS_Uninit()
→ void
The VFS_Uninit function is called immediately before Opus unloads your plugin DLL. It lets you perform cleanup of any initialization that was performed in the VFS_Init function.
VFS_Uninit is called immediately before Opus calls FreeLibrary on your plugin DLL, unless you returned FALSE in VFS_Init.
