Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_testsamepath
VFS_TestSamePath(
     HANDLE:hVFSData,
     LPCWSTR:pszPath1,
     LPCWSTR:pszPath2,
     DWORD:dwFlags
→ BOOL
Arguments
hVFSData
pszPath1
[in] The first path
pszPath2
[in] The second path
dwFlags
[in] Flags
Description
The VFS_TestSamePath function is called to test whether two paths are the same.
See also VFS_TestSameDrive.
This function requires VFSPLUGINVERSION 12122 or later.
