Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_settypeconfigflags
VFS_SetTypeConfigFlags(
     const VFSTYPECONFIGFLAGSW*:lpFlags
→ void
Arguments
lpFlags
[in] Points to the first of a linked list of VFSTYPECONFIGFLAGSW structures
FieldTypeDescription
cbSizeUINTSize of the structure
pNextVFSTypeConfigFlagsW*Next structure, or NULL if this is the last one
lpszTypeConfigIDLPCWSTRString that identifies the type within the plugin. Not case-sensitive
dwFlagsDWORDVFSTYPECONFIG_ flags
dwMaskDWORDVFSTYPECONFIG_ flag mask
Return value
None.
Description
The VFS_SetTypeConfigFlags function is called to set the flags for one or more of your plugin's types.
The following flags are defined:
VFSTYPECONFIG_ENABLEDThe type is enabled
VFSTYPECONFIG_CANCONFIGUREThe type can be configured (see VFS_ConfigureTypeConfig)
Type configs are used by plugins that want multiple entries in the VFS plugin list, one for each type they handle. The plugin must specify the VFSF_TYPECONFIGS flag in VFS_Identify for type config data to be requested. Each type is identified by a string ID, which is not case-sensitive.
See also VFS_QueryTypeConfigIDs, VFS_QueryTypeConfigInfo and VFS_ConfigureTypeConfig.
This function was added in Directory Opus 10 (VFSPLUGINVERSION 4).
