reference:plugins:vfs_plugins:vfs_setfilecomment
VFS_SetFileComment(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     LPTSTR:lpszPath,
     LPTSTR:lpszComment
→ BOOL
Arguments
hVFSData
lpFuncData
[in] unused
lpszPath
[in] A null-terminated string containing the full pathname of the file to retrieve the comment for.
lpszComment
[in] Points to a string containing the new comment for the file.
Return value
If you can successfully store the comment you should return TRUE, otherwise set an appropriate error code and return FALSE.
Description
The VFS_SetFileComment function is called to allow the user to assign an arbitrary comment to a file or folder in your plugin's namespace.
If lpszComment is NULL or an empty string you should remove any previously assigned comment.
