VFS_SetFileAttr(
HANDLE:hVFSData,
LPVFSFUNCDATA:lpFuncData,
LPTSTR:lpszPath,
DWORD:dwAttr,
BOOL:fForDelete
→ BOOL
The VFS_SetFileAttr function is called to set the attributes of a file or folder in your plugin's namespace.
The attribute flags are the same as those in the Windows API. See the documentation for the Windows SetFileAttributes function for a list of flags. You only need to support those flags that make sense in the context of your plugin.
