Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_querytypeconfigids
VFS_QueryTypeConfigIDs(
     UINT:cchMax,
     LPWSTR:lpszTypeConfigIDs
→ BOOL
Arguments
cchMax
[in] Size of the lpszTypeConfigIDs buffer in characters
lpszTypeConfigIDs
[out] Buffer to receive the type IDs
Description
The VFS_QueryTypeConfigIDs function is called to retrieve the IDs of the types your plugin wants to list separately in the VFS plugin list.
Type configs are used by plugins that want multiple entries in the VFS plugin list, one for each type they handle. The plugin must specify the VFSF_TYPECONFIGS flag in VFS_Identify for type config data to be requested. Each type is identified by a string ID, which is not case-sensitive.
See also VFS_QueryTypeConfigInfo, VFS_SetTypeConfigFlags and VFS_ConfigureTypeConfig.
This function was added in Directory Opus 10 (VFSPLUGINVERSION 4).
