Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_queryarchivethumbnails
VFS_QueryArchiveThumbnails(
     HANDLE:hVFSData,
     LPCWSTR:lpszPath,
     LPVFSQUERYARCHIVETHUMBNAILDATA:lpQueryThumbData
→ BOOL
Arguments
hVFSData
lpszPath
[in] Path of the archive
lpQueryThumbData
[in,out] Points to a VFSQUERYARCHIVETHUMBNAILDATA structure
FieldTypeDescription
cbSizeUINT[in] Size of the structure
iNumFilesint[in,out] On input, the maximum number of files that can be provided. On return, the number of files supplied (can be 0)
pszFileNamesLPWSTR*[in,out] Array of pointers to buffers for the filenames
cchFileNameMaxint[in] Maximum size of each buffer
dwFlagsDWORD[out] Flags controlling the appearance of the thumbnail (see below)
Description
The VFS_QueryArchiveThumbnails function is called to get the names of files to use when generating the thumbnail for an archive.
The following flags can be returned in the dwFlags field:
VFSQATF_SINGLEIMAGEProvide one single image rather than multiple images
VFSQATF_COMICBOOKStyle the image as a comic book cover instead of on a "zip folder" background
This function was added in Directory Opus 10 (VFSPLUGINVERSION 4).
