reference:plugins:vfs_plugins:vfs_getfilecomment
VFS_GetFileComment(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     LPTSTR:lpszPath,
     LPTSTR:lpszComment,
     int:cchCommentMax
→ BOOL
Arguments
hVFSData
lpFuncData
[in] unused
lpszPath
[in] A null-terminated string containing the full pathname of the file to retrieve the comment for.
lpszComment
[out] Points to a buffer into which you must copy the comment of the specified file.
cchCommentMax
[in] Specifies the size of the buffer in characters
Return value
If the file has a comment set by the user you should copy it to the supplied buffer and return TRUE. If the file has no comment you should return FALSE.
Description
The VFS_GetFileComment function is called to retrieve the comment set by the user for a file or folder in your plugin's namespace.
This function is not to be confused with VFS_GetFileDescription, which is called to obtain an automatically generated description of a file. The comment this function returns must have been set by the user.
