Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_getcapabilitiesex
VFS_GetCapabilitiesEx(
     HANDLE:hVFSData
→ DWORDLONG
Arguments
hVFSData
Return value
Return a 64-bit bitmask representing the VFS capabilities flags relevant to your namespace. See the Capabilities Flags Reference section for a list of flags.
Description
The VFS_GetCapabilitiesEx function is called to retrieve the capabilities flags of the namespace as a 64-bit value.
This is the 64-bit version of VFS_GetCapabilities. The VFSCAPABILITY_ flags are 64-bit values, and several of them (for example VFSCAPABILITY_ALLOWTAGS, VFSCAPABILITY_ALLOWFIND, VFSCAPABILITY_OUTOFORDER, VFSCAPABILITY_SLOWSEEK and VFSCAPABILITY_NOPRELOADING) are above bit 31, so they do not fit in the DWORD returned by VFS_GetCapabilities.
Not all bits in the 64-bit mask are defined in the header. The undefined bits are used internally by Opus and must not be set.
