Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_getallcustomcolumns
VFS_GetAllCustomColumns()
→ LPVFSCUSTOMCOLUMN
Return value
A pointer to a linked list of VFSCUSTOMCOLUMN structures, or NULL.
Description
The VFS_GetAllCustomColumns function returns the custom columns supported by your plugin, independent of any namespace instance.
Unlike VFS_GetCustomColumns, this function takes no namespace instance handle. It uses the same VFSCUSTOMCOLUMN structure; see the Specifying Custom Columns section for details.
