VFS_FindNextFile(
HANDLE:hVFSData,
LPVFSFUNCDATA:lpFuncData,
HANDLE:hFind,
LPWIN32_FIND_DATA:lpwfdData
→ BOOL
The VFS_FindNextFile function is called to continue the enumeration of the contents of a folder begun with VFS_FindFirstFile.
Currently the only wildcard pattern Opus uses in calls to this function is a "*" meaning return all items. This means you do not need to actually check that the filename you are returning matches the pattern - simply iterate through all files in the originally specified folder.
