reference:plugins:vfs_plugins:vfs_extractfiles
VFS_ExtractFiles(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     LPVFSEXTRACTFILESDATA:lpExtractData
→ BOOL
Arguments
hVFSData
lpFuncData
[in] unused
lpExtractData
[in] Address of a VFSEXTRACTFILESDATA structure
Return value
If the extraction was successful you should return TRUE, otherwise you should set an appropriate error code and return FALSE.
Description
The VFS_ExtractFiles function is called to extract files from your plugin's namespace to a local disk file.
The lpszDestPath field of the VFSEXTRACTFILESDATA structure contains the destination path for the extracted files. The lpszFiles is a double null-terminated list of strings, each one specifying a file to extract from your plugin's namespace.
If you do not provide this function then Opus will simulate it with a combination of VFS_CreateFile / VFS_ReadFile / VFS_CloseFile - so unless you are able to extract files more efficiently than this you may feel free to not implement it.
