Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_endoutoforder
VFS_EndOutOfOrder(
     HANDLE:hVFSData,
     HANDLE:hOutOfOrderData
→ void
Arguments
hVFSData
hOutOfOrderData
[in] The handle returned by VFS_BeginOutOfOrder
Return value
None.
Description
The VFS_EndOutOfOrder function is called to end an out-of-order operation started by VFS_BeginOutOfOrder.
There is no way to report errors from VFS_EndOutOfOrder. Any important errors should already have been reported by this stage.
See also VFS_BeginOutOfOrder, VFS_GetNextFile and the VFSCAPABILITY_OUTOFORDER capability flag.
This function was added in Directory Opus 10 (VFSPLUGINVERSION 4).
