VFS_CreateDirectory(
HANDLE:hVFSData,
LPVFSFUNCDATA:lpFuncData,
LPTSTR:lpszPath,
DWORD:dwFlags
→ BOOL
[in] Flags relating to the create directory operation.
| VFSCREATEDIRF_COPY | The folder is being created as part of a recursive copy operation |
| VFSCREATEDIRF_MULTIPLE | The user wants to create multiple folders at once |
The VFS_CreateDirectory function is called to create a new sub-directory in your plugin's namespace.
If you set the VFSCAPABILITY_MULTICREATEDIR capabilities flag, Opus will allow the user to create multiple folders at once. The VFSCREATEDIRF_MULTIPLE flag in the dwFlags parameter indicates this, and you should treat any commas in the supplied path as separator characters.
