Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_configuretypeconfig
VFS_ConfigureTypeConfig(
     LPCWSTR:lpszTypeConfigID,
     HWND:hWndParent,
     HWND:hWndNotify,
     DWORD:dwNotifyData
→ HWND
Arguments
lpszTypeConfigID
[in] The ID of the type
hWndParent
[in] The handle to the parent window
hWndNotify
[in] Notification window handle
dwNotifyData
[in] Notification message data
Description
The VFS_ConfigureTypeConfig function displays a configuration dialog for one of your plugin's types.
The parameters are the same as those of VFS_Configure, with the addition of lpszTypeConfigID. Types that can be configured have the VFSTYPECONFIG_CANCONFIGURE flag set.
Type configs are used by plugins that want multiple entries in the VFS plugin list, one for each type they handle. The plugin must specify the VFSF_TYPECONFIGS flag in VFS_Identify for type config data to be requested. Each type is identified by a string ID, which is not case-sensitive.
See also VFS_QueryTypeConfigIDs, VFS_QueryTypeConfigInfo and VFS_SetTypeConfigFlags.
This function was added in Directory Opus 10 (VFSPLUGINVERSION 4).
