Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:vfs_closefileex
VFS_CloseFileEx(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     HANDLE:hFile
→ BOOL
Arguments
hVFSData
lpFuncData
[in] unused
hFile
[in] The handle to the file that is to be closed
Description
The VFS_CloseFileEx function is called to close a file handle previously opened by VFS_CreateFile.
It takes the same parameters as VFS_CloseFile, but returns a BOOL.
This function was added in Directory Opus 10 (VFSPLUGINVERSION 4).
