reference:plugins:vfs_plugins:vfs_closefile
VFS_CloseFile(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     HANDLE:hFile
→ void
Arguments
hVFSData
lpFuncData
[in] unused
hFile
[in] the handle to the file that is to be closed
Return value
There is no return value.
Description
The VFS_CloseFile function is called to close a file handle previously opened by VFS_CreateFile.
You should take any steps necessary to close the file (including flushing any write buffers if appropriate) and free any memory involved in the original allocation of the file handle.
