reference:plugins:vfs_plugins:vfs_batchoperation
VFS_BatchOperation(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     LPTSTR:lpszPath,
     LPVFSBATCHDATA:lpBatchData
→ UINT
Arguments
hVFSData
[in] The handle to the existing namespace instance
lpFuncData
[in] unused
lpszPath
[in] Null-terminated string representing the path in your plugin's namespace involved in the batch operation
lpBatchData
[in] Pointer to a VFSBATCHDATA structure that defines the operation
Return value
The return value indicates the result of the batch operation. Currently defined return codes are:
VFSBATCHRES_DODEFAULTThe operation cannot be performed in batch mode.
VFSBATCHRES_SKIPSkip the first file in the pszFiles array and call again for the next file
VFSBATCHRES_HANDLEDFile has been handled by the batch operation
VFSBATCHRES_ABORTAbort the function
VFSBATCHRES_COMPLETEOperation has been completed for all files
VFSBATCHRES_CALLFOREACHSet this flag in conjunction with the SKIP or HANDLED return codes to force the VFS_BatchOperation function to be called for each file
Description
The VFS_BatchOperation function is called to initiate a batch-mode file operation involving your plugin's namespace.
As well as returning one of the above codes to indicate the result of a batch operation, you should also fill in the piResults array (supplied in the VFSBATCHDATA structure) with a result code for each of the specified files - either 0 for success or an error code on failure.
