reference:plugins:vfs_plugins:plugin_initialization_and_usb_export
When Opus first initializes your VFS Plugin, it calls the VFS_Init function (if exported). Exporting this function lets you perform initialization that it is not safe to perform within the standard DllMain function (eg, opening libraries.) Similarly, VFS_Uninit is called when Opus is about to release your plugin.
To support the new USB export feature of Opus 9, plugins need to mark themselves as being "USB-safe". This generally means that plugins must not write to the registry, but instead store their configuration data in XML format using the routines provided by the Opus Plugin Support API. To mark your plugin as USB-safe you need to export the VFS_USBSafe function. This function also lets you indicate to Opus the names of any additional files that must be exported along with your plugin (eg, the rar.dll plugin also requires the unrar.dll library to be present.)
