Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_writefile
VFS_WriteFile(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     HANDLE:hFile,
     LPVOID:lpData,
     DWORD:dwSize,
     BOOL:fFlush,
     LPDWORD:lpdwWriteSize
→ BOOL
Arguments
hVFSData
lpFuncData
[in] unused
hFile
[in] File handle as returned by your VFS_CreateFile function
lpData
[in] Pointer to a buffer containing the data to write
dwSize
[in] Size of the data in bytes
fFlush
[in] Set to TRUE if you should flush any write buffers to disk after completing this write operation
lpdwWriteSize
[out] Pointer to a DWORD to receive the amount of data written successfully
Return value
The function must return TRUE if data was successfully written to the file, or FALSE on failure or end-of-file. You should set an appropriate error code on failure that Opus can retrieve via VFS_GetLastError - the error code should be set to 0 for an end-of-file condition.
Description
The VFS_WriteFile function is called to write data to an open file.
You must write as much data as possible up to and including dwSize bytes to your file from the buffer provided. The amount of data actually written must be placed in lpdwWriteSize.
