Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_uninit
VFS_Uninit()
→ void
Return value
None.
Description
The VFS_Uninit function is called immediately before Opus unloads your plugin DLL. It lets you perform cleanup of any initialization that was performed in the VFS_Init function.
VFS_Uninit is called immediately before Opus calls FreeLibrary on your plugin DLL, unless you returned FALSE in VFS_Init.
