Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_setfileattr
VFS_SetFileAttr(
     HANDLE:hVFSData,
     LPVFSFUNCDATA:lpFuncData,
     LPTSTR:lpszPath,
     DWORD:dwAttr,
     BOOL:fForDelete
→ BOOL
Arguments
hVFSData
lpFuncData
[in] unused
lpszPath
[in] A null-terminated string containing the full pathname of the file to retrieve attributes for.
dwAttr
[in] Specifies the new attributes for the file.
fForDelete
[in] Set to TRUE if this is being called to unprotect a file for a delete operation
Return value
If the attributes were successfully changed you should return TRUE. If the file does not exist or another error occurs you should return FALSE.
Description
The VFS_SetFileAttr function is called to set the attributes of a file or folder in your plugin's namespace.
The attribute flags are the same as those in the Windows API. See the documentation for the Windows SetFileAttributes function for a list of flags. You only need to support those flags that make sense in the context of your plugin.
