Sidebar
Using Directory Opus
Configuration
Programming
Reference Section
reference:plugins:vfs_plugins:exported_functions_reference:vfs_propget
VFS_PropGet(
     HANDLE:hVFSData,
     vfsProperty:propId,
     LPVOID:lpPropData,
     LPVOID:lpData1,
     LPVOID:lpData2,
     LPVOID:lpData3
→ BOOL
Arguments
hVFSData
propId
[in] The type of property to retrieve
lpPropData
[in/out] The meaning of this parameter changes depending on the property type
lpData1
lpData2
lpData3
Return value
The function must return TRUE if the property was successfully retrieved, or FALSE on failure. You should set an appropriate error code on failure that Opus can retrieve via VFS_GetLastError.
Description
The VFS_PropGet function is called to retrieve several properties for files or folders in your plugin namespace, or for the namespace itself.
Generally, lpPropData will point to a variable or buffer for you to return the necessary property information, and lpData1, lpData2 and lpData3 will be used to provide additional information about the property request. However this is not always the case and you should read the documentation in the Property Reference section for a full listing of the property types supported by this function.
